Posts: 148 |
I am looking into doing a full 3L swap or a hybrid.
My main consern is final HP numbers and reliabilty. My coworkers dad is an expert mechanic that mantains a 800 HP Sanoma Drag truck but i am just not sure if i should go full 3L route or do a hybrid. Also, if i do go full 3.0L and i buy new heads to bump the stock compression ratio, is that pretty much doing the same thing as using stock 2.5L heads and PnP'ing them?
1998 Black SVT (#469 on 4-24-1997)
Custom Cougars CAI
Custom Magnaflow exhaust
opt. jet-hot-coated Y-pipe
B&M short shifter
Stazi Rotor & Brake kit
17x7 Enkei RO56's
Mirco Splitter
15.45 @ 89.03 (Stock /w worn clutch)
172HP 164TRQ (stock)
Posts: 4,970 |
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 638 |
Originally posted by TrumpDrewSVT: Also, if i do go full 3.0L and i buy new heads to bump the stock compression ratio, is that pretty much doing the same thing as using stock 2.5L heads and PnP'ing them?
Cut 3L valves into the 2.5 heads, then do a PnP, and that's kinda like having full 3L heads, except you'll have split port w/ cam driven water pump (something not avaliable with 3L heads), as opposed to oval port.
87 Mustang GT 5.0L TURBO
Posts: 1,238 |
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 411 |
Originally posted by Pope: ....except you'll have split port w/ cam driven water pump (something not avaliable with 3L heads), as opposed to oval port.
I'm about 101% sure that you can have a cam driven WP w/ 3L heads.... unless you specifically meant split port 3L heads w/ cam driven WP- in which case, nevermind....
-Chuck Dienzo
Black 98.5 E1 SVT
#5022 of 6535
Born on March 16, 1998
"If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
Posts: 9,602 |
Originally posted by Pope: except you'll have split port w/ cam driven water pump (something not avaliable with 3L heads), as opposed to oval port.
01+ oval port heads have the cam driven water pump.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 638 |
