#1264811 05/02/05 01:24 AM
9
whats the best way to launch an atx? ive kind of been experimenting around and still cant run faster than 17's with a duratec
Metallic Steel Blue 99 SE Sport ATX college= few mods Infinity Kappas just added I have no secondaries! SELL ME YOUR WORKING IMRC box!!!
#1264812 05/02/05 01:39 AM
Interesting
First off, don't be downed by your track times. The point of the track is to run your car before and after any changes.
Secondly, there could be a few things you can check. Throttle Hang, appropriate air pressure in your front and rear tires (amount of tread; but that's obvious).. I'm sure there's more I just can't think of at the moment.
If we're talking about a stock automatic Non SVT Duratec, that number sounds to me to be in the right time frame. Before any modifications to my car, my 0-60 mph time was something like 11 seconds.
#1264813 05/02/05 02:29 AM
I was hoping for some answers too but this is what I found. hold the brake and the gas to about 2000 rpm and let off and floor it. Not the best for the car, but unless you do it at every light, it won't hurt to do it every once and a while. I think its called brake lag. otherwise, if you just floor it off the start my turtle will probally keep up til it hits 4500 rpm. But I heard 0-60 in 8.6 seconds form magazines, but thats also by professional drivers. I got 11 seconds just flooring it without brake lag or anything so it might be possible.... any other suggestions?
95 LX-with a mind of its own 24v DOHC SVT exhaust and K&N=all thats worth modding Go Fighting Sioux!!!
#1264814 05/02/05 02:55 AM
F
F
Thats what i did, xcept i don't have a tach, so i had to guess. I just held the gas and brake down at a decent rpm level, and let the brake off and floored it. Now, i have a zetec and i ran 18.2 at 76.8 as my fastest time , but only a K&N and autolite double-plats and ford racing wires as engine mods. I also kept the overdrive off, which helped.
A Contour is not just a car, it's an experience 99 T-Red SE Zetec ATX Born April 16, 1999 98 E0 Silver Frost CSVT #3175/3565 Born August 21st, 1997 Stored at P.R.T. for the winter 67 Mustang 289 project car
#1264815 05/02/05 05:04 AM
If you are going to partake in going to a track.. do yourself a favor: look in to wheel hop, and how INCREDIBLY HARMFUL it is to your car (ie.. It's not the best for your car, but if you don't do it at every light... etc) not saying that that poster was referring to it, however statements like that can be misleading and portray a feeling of unimportance on the entire event.
in a nut shell... don't hop...
keep your rpms at a point just below hopping. as you begin moving, you want your goal to be: keep your rpms up, but don't hop or spin. Ideally, once you are out of the box, your secondaries should open up and off you go. shoot for the quickest 60ft time you can. Each tenth in the 60 is about equal to 2/10 in the 1/4.
Also remember that your reaction time has NOTHING to do with your 1/4 time. you can sit there for 2 minutes after the staging lights go green, and still run a 16.
Stats for your car are readily available throughout this forum (dyno&drag)
Ray
Ray
#1264816 05/02/05 06:01 PM
9
Thats how I launch... My car ran a 16.4 @85mph... It does have an optimized TB though (not that it made that much difference). Even last year, when it was stock, it ran a 16.8@83mph...
Keep in mind that my car is also extremely well maintained. New plugs, UIM/LIM/Heads cleaned by hand, stuff like that. Maintenance and the little things will make the difference...
1999 Mystique LS V6 Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
#1264817 05/02/05 08:02 PM
Hold brake and gas. It's only gonna go to the stall speed (2500rpm i think) no matter how far you have it floored. I think somebody (unisys maybe) found that getting the motor mounts loaded up and launching at that point is best. I don't really know how to feel that point, it mite just be a duratec thing.
Anyways, ran 11 flat @ ~65mph 1/8 mile with 17" wheels, stock cam gears, and stock hood.
#1264818 05/03/05 05:26 PM
I gotta try this =)
165,000 miles and still running strong! '99 Contour SE [ Duratec V6 - Minor Mods ] '01 Hyundai Elantra '03 Volkswagen Jetta
#1264819 05/06/05 02:37 PM
FWIW - After driving my '96 for 9 years and 165,800 miles now, I have found that setting the OD off, braking hard and throttling to about 2200-2300 (not quite full throttle) and then dumping the brake and flooring it simulateously will result in spinning the front tires for about 1 1/2 revolutions on dry, clean, flat, 70-80 degree asphalt. The tires then hook and off you go. This is with 24" OD 225/50-15 Dunlops on 15X7 alloys. Bigger diameter tires will, of course, reduce your acceleration. It's like running taller final drive gearing. For drag racing, run the shortest tire OD you can without tire spin.
My only mods are listed in my signature area.
While we are on the subject, is there a way to install a lower ratio final drive gear ratio in an ATX? I have an '05 Escape that I would just love to put a lower drive ratio into.
'96 SE 2.5 V6 ATX, Willow Frost Metallic 10-hole '84 Mustang 15x7 wheels w/ Dunlop 225/50-15's CSVT air intake components with K&N cone filter Optimized TB Gutted Pre-cats w/MIL eliminators
#1264820 05/08/05 08:08 PM
i managed to do 16.251@85.42 mph completely stock, with my brother in the car with me. I did the brake thing, but the key is cooler air getting to the engine. It sounds silly but my first run was 17.4 and to drop it to where i was i just iced the intake, which gave me cooler air...yada yada yada...
ATX -
Originally posted by bnoon:
Get enough HP/TQ and some traction and you can race a ricer one handed while sipping a slirpy. Nothing wrong with that.
<font class="post"> 16.251@85.42 mph
Moderated by  mbb41_dup1
