#1263524 04/30/05 12:37 AM
My car has had this problem recently, it like to idle at around 1200-1500 rpms. I replaced the TPS and the IAC, and cleaned the MAF. It idles sometimes, but most of the time it will not idle at the normal speed. Any other ideas as to what may be causing this problem?
Thanks,
Mark
1998 T-Red SVT Contour #2588 of 6535 2005 F-150
#1263525 04/30/05 01:42 AM
Vacuum leaks.
#1263526 04/30/05 05:56 AM
You may want to check the throttle cable too.
