Posts: 3,065 |
Ohhhh it is so tempting to get my calipers power coated.
Posts: 1,572 |
Originally posted by Matt R: Ohhhh it is so tempting to get my calipers power coated.
Send away !!
Anyway for the text just give me a few options and i will try and make it better for you , I see it perfect with no issues at all ...
TEXT IS CHANGED .............is it better ?
Check me out for awsome powder coating deals
www.powdercoatingworld.com
People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
Posts: 286 |
Much better.. Now just educate me on what a Ford Contour Brack Caliper, and I'm set.
Posts: 1,572 |
hmmm no idea
Posts: 4,220 |
The problem with that bright red text is that it appears to "bleed" into the surrounding area, making the letters very blocky looking.
Personally, I'd ditch the red altogether or replace it with some sort of graphic. As text it's just redundant with the white text directly beneath it.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 1,572 |
Originally posted by sigma: The problem with that bright red text is that it appears to "bleed" into the surrounding area, making the letters very blocky looking.
Yes i see that too ,I cant delete it cuase there has to be some type of a image in that spot ,someone wanna make me the same images in the same size "transparent" i will use them .'
Anyone ?
Posts: 1,580 |
Just remember if you're ordering to use #1007 as your referral number
** Mike **
"You might beat me in a straight line, but I'll embarass you in the turns"
Posts: 1,516 |
It seems IE doesn't like my code, so if you order something in IE the sales rep box doesn't show up correctly. Ray, I like your idea of Discount Code, I will change it when I fix it into whatever Bill Gates wants me to change my coding to (apparently not HTML)
Cameron
98 Black CSVT #2958
Posts: 1,516 |
Ok, everything is working.
Cameron
98 Black CSVT #2958
Posts: 1,572 |
I hope i got everyone's address, I had to revise the back of the cards to show the address of the place .I should have all 5250 cards between Tuesday and Thursday .I will let you know if i don't have someones info , it's not that easy digging through 584 PM's from yo people !
Is everyone who signed up through this signed up on the site ? If so I won't have to sort thuogh all there PM's !!!!
