do you guys suffer with hg problems like uk spec mondeo do
either front or rear bank leaking
and the ticking noise too
rs body kit 2.0 tb bomz kit piper exhaust 3.5" megaleads ht 16" cossie rims Meg sticker ghia maplight/passager rear light ice under bonnet bling Auto wiper in reverse the first Mk1 windows on mod with ignition off
no body then
just seems to be common problem
and is very costly too sadly
but the v6's make such nice cars to drive for power and torque
No US 2.5L engines have had any head gasket problems.
The stock head gaskets have even held over 400 FWHP from turbo charged cars as well.
They are quite capable.
mine leaked.. it was a 97 tho with a hard 145k on them...
it needed a re-build but still had the power of it being brand new
Mark 1998 T-Red SVT -Needs more Go 1999 Light Prairie Tan, Se Zetec www.cardomain.com/id/tour4reak
JB1 Offline
i'm such an absent minded geek. i read the first post earlier today and instantly connected hg with mercury and then wondered wth was taking about. doh. head gasket didn't even occur to me. lol
00 black/tan svt, #2052 of 2150, born 2/1/00 formerly known as my csvt "Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
O
ODC Offline
O
The UK versions seem to be blessed with better waterpumps and fuel pumps though. They also have the DMD stock and isn't spun bearings a rarity ?
V
V
Don't feel bad, at least you remembered what element hg stands for
E0 #36 '95 Ranger '82 Honda CX500
no the water pumps are plastic ones and break up all the time causing engine to over heat cooking the heads
but we can get hold of the metal water pumps
also dmd pulley too
so the us v6 doesn't suffer like the uk spec
does any1 know why this is or not
also on both gaskets there a bit missing which should cover a bit of the heads have you guys have the same problem with this too
link to meg about some of the head gasket problems to take a look at see what you think and comment on
http://www.fordmondeo.org/ubbthreads/showflat.php/Cat/0/Number/626878/an/0/page/0/gonew/1#UNREAD
No, no, and no.
Same water pump. (Ford Europe has used non-silicate/non-phosphate coolant for years though. )
Same fuel pumps. (maybe a different pickup screen for the returnless though?)
They use the same crank pulley.
I'm pretty sure my head gasket is leaking oil. It spatters out of the seal on the rear head once in a while and the back side of the block is always wet. It's not real bad yet (first time i actually noticed thats where it's coming from)... but i only have 45k miles. I'm thinking about trying a heavier weight oil or using some of that stop leak you can get anywhere. No one else has had this problem?
CSVT#1321/2150 Born 1/6/2000 It's just a Contour.. Before Dyno: 178.9whp w/2.5L 94 Probe 4cyl/150k KYB struts, Magnaflow Polished SS muffler (Daily Driver)
