Posts: 26 |
Hey guys, What are some basic mods to get a lil more out of my 97 V6 Auto?
Total price I want to initially spend on first mods is around $500.
Thanks
1997 Contour GL V6
Posts: 1,609 |
trans cooler!!! Because you have the ATX a trans cooler is a must due to the fact they overheat.
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Posts: 6,791 |
Definetely go with an intake. You can get the pipe from a few places... Check out SPmotorsport.com. You'll need a maf adapter, from SP as well. ANd pick up a K&N RU3530. Very popular choice. Next i would say go with an svt exhaust... Or maybe some other type of cat back. There are many other things you can do, use the search and check the stickies.
Posts: 6,700 |
There are 5.. yes 5 threads right above you about how to modify your duratec.... I know for a FACT you can find anything and everythign you want in there.
Common mods under 500.00...
Exhaust, Intake, Chip, Pulleys, Nitrous Fogger, oil pan, accusump, list goes on.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 1,746 |
There are tons of posts about mods to do for cheap. Use the search function up top to get some more info or idea's. A Chip should be saved for last so you don't have to have it reprogrammed after you've done more performance mods to your car. For $500 you could buy a MAF adapter, K%N filter, and a Trubendz Catback Exhaust. That will exhaust your funds and will get you to the next step. MAF adapter - www.spmotorsports.com - $39 K&N (RU-3530) - www.ajusa.com - $33 Trubendz Cat-Back - www.trubendz.com - $340 and up
2000 Contour SVT
SF - #542 of 2150
Posts: 1,506 |
I don't know what an AT cooler costs, but that sounds damn important to me, as pulling/fixing/replacing a tranny is $$$$. Limited to only $500, look for a cheap adapter and that K&N 3530; if you can find a cheap svt catback exhaust, that's an improvement; and here's one with the best bang/buck payoff: optimize your stock y pipe or get a cheap used good aftermarket one. Even if you have to pay someone to do it or install one for you. Precious few mods get you ~4 HP for ~$100. Do all of these together and you will feel the difference. Then if you're eager to use wrenches, buy some gaskets and clean your UIM/LIMs.
PS: Later on, avoid buying heavy wheels that slow you down.
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
Posts: 26 |
Originally posted by starjammir: trans cooler!!! Because you have the ATX a trans cooler is a must due to the fact they overheat.
Thanks
Sounds like I will get an intake and definitely a tranny cooler. What brand do u recommend? Where do u recommend buying it from? Also the Y pipe will probably get done.
Thanks
Oh as far as the wheels, I have the lil stock 14s on there now... they cant be too heavy, but they sure are ugly...
1997 Contour GL V6
Posts: 1,609 |
I do not have one yet but its on the top of my mod list as of right now...I would get the B&G super cooler...thats the one that I am going to get...I believe it is on JC whitney along with other ones like Summitracing..etc..you will have to get some adapters to work with our trans and some trans hose but thats about it...should be under 100 bucks if you do it urself
Posts: 1,241 |
Originally posted by promiscio: I have the lil stock 14s on there now... they cant be too heavy, but they sure are ugly...
you should pick up a set of E1s from a 98.5+ SVT. They are always popping up in the classifieds and go for good prices.
Jake
96 T-Red SE V6
