Page 2 of 2 1 2
#12614 07/25/02 02:37 AM
[QUOTE]Originally posted by Big Jim:
[QB]It was suggested from the 3.0 Duratec Forum that an explanation of the gasses read in a smog test may be of interest. I will try to make a reasonably complete but brief explanation.
i would hate to read the non-brief explanation.
98 Black SVT
It's all coming, soon!
#12615 07/25/02 11:53 AM
Scott,
As your mixture becomes leaner you have an excess amount of air. The extra air helps to cool the combustion. I believe what you are confusing is exhaust gas temperature and combustion temperature. As you lower your exhaust gas temperatures generally you have a more efficient engine (less energy going out the exhaust). That is why when you retard your ignition timing NOx levels will go down, combustion temperatures are going down which leads to less NOx formation, yet your exhaust gas temps will tend to go higher as the combustion is not efficient also causing higher CO levels and unburned fuel coming out the exhaust.
Page 2 of 2 1 2
