I will clean the IAC valve out with some carb cleaner and work some carb cleaner into the TB and butterfly. Hmm..didn't know they didn't have an idle screw on contours..guess I am to used to fixing my stang problems. Also, i was checking on the corral (stang form) and they mentioned that the wiring under the battery tray tends to corrode.
"There is a Recall/TSB on Contours where all the wiring under the hood is subjected to fraying and cracking open. Did you ever check the history of the car to see if has been checked yet?? Sorry, I dont have anymore specific info on it, but when I worked at Ford, I did quite a few of these checks. Talk to a service writer at Ford, could be another TSB. Good Luck"
98 Contour SVT:
MUSTANG: 87 GT 5.0: TFS Twisted Wedge heads, TFS 1.6 Roller Rockers, Cobra 5.0 Intake, 3.73 gears, 76mm C&L MAF, JBA Headers, Moroso CAI, Steeda Tri-Ax Shifter
