Here are more of the same symptoms of other posters in this section. After I had the idle re-set on my '95 GL (4cyl. auto) because it was stalling during reverse and stopping at lights: now, it runs like doo doo when cold, stalls and stumbles, rev the engine in park and it breaks up. The mechanic who set the idle with the aid of his computer, said he cleaned the fuel plenum????, is that right? The cars runs normally when warmed up and gives pretty good mileage as long as I don't floor it. On top of that, the rear struts are going bad and the rear end clunks all the time. AND, there is a coolant leak in the main a/c line. If the rear struts are bad, are the front shot as well? I have owned this car for two years and also had the left control replaced (after I launched the car off a lane separator on the road) and also had a new gas tank put in because it leaked at the pump. Am I nuts? it has 101,600 on it and I now wish I could just kiss it goodbye, but everything I spent up until now would be down the drain.
