Page 3 of 3 1 2 3
#1256507 04/26/05 12:41 AM
Originally posted by LilStripedRocket:
Originally posted by Y2KMondeoSVT:
Thanks goodness it had nothing to do with the center console **wipes forehead** !
Maybe once the fitting dries out , the CEL will go away (wishful/positive thinking) .
It's still your fault.
Ouch ! LOL
~~~~~~~ Phil Black & Tan 2000 SVT Contour #2137 of 2150 35,000 miles & counting !
#1256508 04/26/05 05:26 AM
It sounds like your problem's fixed, but I wanted to post the 'testing 02 procedure' for you and anybody else searching this post.
First Test
1) Disconnect the 02, but leave the battery connected
2) Measure the resistence between the PWR and GRND terminals of the sensor. it should be approx 6 ohms at 68 degrees F.
Second Test
1) With the sensor connected and the engine running, measure the voltage between the H02S and SIG RTN (Ground) of the 02 sensor. voltage should fluctuate between 0.01-1.1 volts.
If the first test doesn't read around 6 ohms, or if the second test yeilds slow fluctuation or voltage isn't within specification, replace the sensor.
I hope you don't have to replace your sensor , but if the cel comes back on, try out these tests and let us know the results.
-glenn "Always workin to pay for the maintenance of my 'tour." 99 CSVT - Superchip, K&N Short Ram Intake, Pro Street 52" Blue Neons, Highs in Lows, Drilled/Slotted Rotors, Vortech SC is on the way...
#1256509 04/26/05 11:27 AM
Thanks alot "alwaysworkin".. sound slike yours is always broken, lol. I've been searching the boards and the haynes manual for this procedure.. just couldn'
t find it. But thans, now. I'm going to crawl under there and take a look at it and test it, just to make sure it's 100%. If not,. out she comes and i'll pu a new one in. THaaks a lot guys, glad to see the helpfull faces of CEG come together for me.
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
Page 3 of 3 1 2 3
