First off, a dyno tuned chip should be the LAST step of tuning.
Its about making everything work togther to its max capability.
If your using it as a step in the process, do not dyno tune it, jus tuse an "off the shelf".
Considering the wide range of possible mod combinations, ECU codes, and factory tolerences, it would be very hard to tune for every case.
Its a trade-off, you "generaly" tune to a number of combonations that can be tailored to an ECU code.
Can certain extra features be programmed into gain power that don't need dyno tuning? Of course.
Is SCT a very good option? Yes.
If it was possible to tune a car without a dyno so well, everybody would do it.
Simple fact is two cars, with the same mods, can and will dyno differently.
You can even swap the ECUs and they'll still dyno different.
