#1255122 04/22/05 10:13 PM
I have been searching the archives for about an hour now and can't find a similar problem. My contour has a clanking noise coming from the driver side front end. It sounds like a loose piece of metal. The car drives straight and handles fine, the noise appears going over short sharp bumps (potholes, sudden changes in pavement). I have looked under the car and can't find anything out of place or loose. What could it be? Any ideas would be greatly appreciated.
Kip 98 CSVT Black/Midnight Blue
#1255123 04/23/05 12:19 AM
Welcome..
I will do both jobs here:
[search nazi] If you looked for an hour, you would have EASILY found PAGES of information on this subject...[/nazi]
[helpful guy]Welcome to CEG.. This is a fairly common problem, and is often caused by a broken spring, or spring perch, which is located fairly high within the suspension system, and can be pretty hard to see, if just "looking".. All can look fine. check further up than you would "normally" look..
Also can be bushings, as well.
Ray
#1255124 04/23/05 02:24 AM
so, what to do about it? i have the same problem, only it is the passenger side.
remove strut and replace said spring or spring perch?
i've never owned a car with coil-overs...
edit!!
ok, just did a search. seems the poor little contour/mystiques suffer from cheap little ball-point pen springs that are prone to breaking. gotta be it. when i bang on the spring, i can replicate the noise my suspension makes when hitting a bump or going over a heave in the road.
this forum rocks.
1996 Mustang Cobra Convertible 1998 Mercury Mystique 4cyl Auto
#1255125 04/24/05 04:35 AM
Can the rear end do this too? I am getting the same noise but its coming from the rear end. Thanks.
Alicia 96 Contour LX 2.5L V6 Duratec Stock of course! BAD ASS GIRLS DRIVE BAD ASS CARS!!! http://www.cardomain.com/id/sweet_ride01
#1255126 04/24/05 03:19 PM
sure it can... on the main page (contour.org) then go to FAQ, then common complaints/problems
under (I think) drivability...
Ray
