#1254874 04/22/05 07:53 PM
SVTatGT Offline OP
How hard is it to replace the started on the v6. I have the service manual and it looks fairly straight forward, but i am worried that I will run into something that they don't describe. Anyone who has done this before have any advice?
Cameron 98 Black CSVT #2958
#1254875 04/22/05 09:41 PM
Yeah it's not that bad...I can't imagine it being difficult on an MTX. Small hands are always a plus though! It really isn't that bad, just two bolts and you're good. Just make sure you take out the battery first...cough cough Stazi
99 Black Contour SE Sport
#1254876 04/22/05 10:02 PM
Remove the airbox, filter, and battery.. battery tray would be a plus, as well..
Two bolts hold it in.. fenagle your way out of the coolant hose mess, and then replace.
Ray
#1254877 04/23/05 03:19 AM
SVTatGT Offline OP
How do you get at the bolt towards the front of the car. I got the back one off with an extension, but i dont see how a socket will get onto that front bolt, do i have to resort to a wrench?
#1254878 04/23/05 03:25 AM
If the only thing standing between you and getting the starter out is "finding out" about whether or not to use a wrench, I want to know why you came in here, instead of just "resorting" to getting a wrench..
lol
a deep socket may work, actually, but I used a wrench, fwiw.
Ray
#1254879 04/23/05 03:27 AM
SVTatGT Offline OP
Hahah, the problem is that I couldn't find the wrench, so i was wondering if I should resort to looking for it.
And as I thought, I will be going to look for it...
Thanks for the help guys
#1254880 04/23/05 05:56 AM
Gear wrench on the front bolt.
Socket, universal, and extension on the rear bolt.
DON'T drop the rear bolt.
I can do it in 15 minutes. Though I don't have a battery there and my intake removes via just once clamp and 2 plugs.
Probably take an hour or so otherwise.
#1254881 04/23/05 06:05 AM
SVTatGT Offline OP
How do you remove the power line on the starter, I can't see what I am doing back there...
Sorry for all the newb questions, the most complicated thing I have ever done to a car is change the oil, so this is quite a step up for me
#1254882 04/23/05 06:52 AM
Uhmm there are two bolts that connect the starter motor to the bracket which apparently you've take care of. Then if I remember correctly, there is a starter electrical connector above the starter motor itself that you have to pull out...I would take a look at my car, but it's parked outside and it's raining...hope someone else can chime in on this.
#1254883 04/23/05 05:50 PM
SVTatGT Offline OP
All done. Works great. Getting that starter in and out was a [censored] becuase my battery tray was rusted to the frame
Thanks again for all the help guys
