I use a hydrolic jack and then place a 2-ton jackstand under there to for added safety. You should never rely on a floor jack/hydrolic jack to hold the car for you.
It's main purpose is jacking, not holding up the car.
I've changed the oil on my 03 Focus/Zetec and it's pain but at least you can get an oil filter wrench in there.
All I can say is... Wow....WTF was Ford thinking with the Contour Zetec ???
There's probably no way an oil filter wrench is getting on there, more less your hand getting enough room to move the oil filter.
Well, with some persistance, I got the filter off by hand.
What a PITA !!!!!
Getting it back on wasn't that bad but man, I must say that's the worst spot for an oil filter on any car I've ever worked on.
Anyway, I used a Motorcraft Fl-2005 and that new Mobil 5000/6 month oil, which isn't synthetic but only $1.50 a quart a Walmart.
Also, my local Walmart is phasing out Motorcraft parts...
Now, I need to find my Fl-2005 somewhere else.
Anyway, anyone attempting to do this for the first time, be prepared for some anguish and torement from the mighty Contour Zetec. If you're lucky, you'll be spared some cuts, nicks and rashes from getting your hand inside the oil filter area...
Make sure to have a wide oil pan to catch all the oil that's going to drip/come forth when you turn the oil filter. I used some oil rages(4 to be exact) and it still didn't absorb all the oil that came out of the filter...
Good luck and be patient.
