i am currently having an issiue with my power locks (i allready swaped out every fuse incase parts of the locking system are controled by other fuses)... my drivers side lock button is not working(but my passanger side is. i allready tryed swaping the drivers side button a with the passengers but still no luck) all 4 locks work from the passenger side control and all 4 light up with the headlights on... when i manualy lock or unlock the drivers, Rear drivers, or rear passengers door there is no "BUZZ" sound... any one have any idea on what i should start searching for.
RIP Frank Foreman. March 15 2005. died in a tragic car crash at the age of 18.<Drive Safe> 1995 Contour gl Zetec auto. 178000km
ummm...im not to sure what its called but its that rubber hose looking thing near the hinges on the door..its got the wireing harmess inside...mabe clean that out or check the connection...thats the only thing i can think of if u did everything else
kevin m 98 T-red mystique gs zetec ATX | my ride |
V
V
I had the exact same problem & the accordion/rubber hose thing ended up being disconnected somehow.
You should check that first. IIRC, there are 2 & cleaning the terminal w/ electronics spray cleaner wouldn't hurt either.
-Chuck Dienzo Black 98.5 E1 SVT #5022 of 6535 Born on March 16, 1998 "If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
