Posts: 184 |
what are the differences between a 98 se and a 98 csvt? be somewhat specific because im trying to convince my parents to let me a get a svt. i already have a se, but i dont know all of the difference. they can be any thing ( exterior, interior, motor & accessories). thanks in advance
Posts: 1,322 |
Go to ... Main site, look at brochures, and FAQ. There may be a better way but that has some good information, AND SEARCH!
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 4,693 |
20 more horsepower.
Larger throttle body (60 mm vs 54 mm).
Different air filter and intake (cone style using same air filter as V6 Mustang).
Intake manifold ported using the extrude hone method.
Primary intake ports on head extrude honed.
Cams providing slightly more valve overlap.
An engine oil cooler.
Radiator has thicker core for better cooling.
Quasi dual exhaust.
Manual trans only (5 speed).
Stronger clutch.
Lighter flywheel.
Larger front brakes.
As with all 98 manual trans V6 Contours, rear disc brakes.
Revised motor and trans mounts.
Unique front and rear bumper and rocker panel skirts as part of the SVT ground effects package.
In 98, a unique interior. Midnight blue with perferated leather seating surfaces. In 99 tan interior also became available.
White gauges.
Factory Premium Sound, either am-fm cd player or am-fm cassette player.
The early 98, same springs and struts as other V6 manual trans Contours, but with different front and rear sway bars.
In late 98, re-valved front struts for SVT only that were a bit stiffer but mainly kept car from lifting as much on acceleration or diving as much on braking.
205/55ZR16 tires. Early 98 wheels different from late 98 and newer. Early style often called "Cosworth" style and late 98 and newer more like the Cobra wheel for SVT family identification. Both wheels look very good.
Available in Black, Silver, or a slightly maroon toned Red. A deep green was added in 99.
That's about all I can think of off the top of my head.
New, an SVT sold for about $5,000 more than a nearly equilivant SE and non of the incentives (rebates or lower interest) were available for the SVT.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 4,292 |
19lb injectors leather shift boot hand picked crankshaft early svt's had bigger front brake calipers,used on the ford rs,etc. then they switched to the smaller calipers on the standard tour/stique/cougar, but with bigger mounting bracket to use the 278mm front rotor later models after 99 got the daul extrude treatment to the upper intake manifold,and larger ports on the lower intake manifold the svt pcm also got a more aggressive treatment...
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 7,100 |
I could have SWORN I posted this once, already, and now its gone... 98 SE compared to a 98 SVTRay
'99 CSVT - Silver #222/276
Posts: 184 |
thanks for all the input guys! yea im a lazy bastard i only tryed searching for like 5 mins. but so far its looking quite promising with the folks. wish me luck ( im going to the dealer again mid-next week)
Posts: 184 |
also on a side note, how strong is the mtx-75?
Posts: 2,166 |
Originally posted by SenorDuckie: also on a side note, how strong is the mtx-75?
Stronger than the ATX, if that's what you're asking.
- Zack
WANTED: T-Red HEATED Side Mirrors
FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps
2000 T-Red SVT
1995 LX V6 MTX (RIP)
Posts: 4,693 |
Overall it is very strong. Strong enough to handle large horsepower increases from engine modifications.
It is not without it's weaknesses though. The weakest point is the final drive (differential). It is only a two pinion design. The common cure for this is to install either a Torsen or Quaffe LSD unit that replaces the diff and are nearly bullit proof. There are several upgrades available to make the trans shift smoother from better fluid to shift forks with bearings on the shafts to improved synchro's (a slightly loose 3rd gear synchro is so common that it is nearly normal).
If any of the trans problems are bad enough that better fluid doesn't make it livable, there is plenty of help available.
With over 200,000 miles on my car, I have not yet needed to do anything with the trans or clutch except change the trans fluid and the clutch (brake) fluid ocassionally.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 7,100 |
Excellent info, Jim.
Also, Duckie.. Post the vin, mileage, and cost of the car, as well as any defects, or trouble spots you notice. This can further help you to know what the car is worth, etc.
Check for the bad synchros in the tranny (either 2-1 downshifting or 2-3 upshifting are most common)
Ray
