#1248498 04/16/05 11:47 PM
I
I
Now that I finally got my new chip from ADC to replace the bad one I got, do I need to pull the 4 and 11(?) fuses before I put it in? i know you are supposed to do this with other mods.
1999 Tropic Green SVT Contour MODS: Some.....always more coming
9
how did you know the chip was bad???
I
I
car wouldnt start no matter how much i cleaned the connectors
I
I
im juts curious if i should pull the fuses this time
Every single time you make a change.
Z
Z
Yes pull the fuses, but be 100% sure that your computer board is spotless on both sides before you put the chip in or you could have another problem.
98 Contour SE 3.0L 5-speed SCT PRP, Gutted IMRC's, Fidanza Flywheel, Race Ported 2004 3.0L Oval Port, Zex 125hp shot, 70mm Mustang TB, 42Lb injectors,Walbro 255 pump, Traction Bars, Zeitronix wideband o2, lots of little things, 10,000K HID's!!
I
I
any different than just unhooking the battery?
Nope, it's the same thing.
Yes.
It doesn't erase your aftermarket stereo settings and/or your clock.
It's much quicker IMO.
