Posts: 448 |
97 zetec sport
101,xxx miles
problems: NIL
best car i have owned.
Posts: 731 |
57,000 miles Replaced under warranty: ABS Module and #3 Fuse in engine compartment (Controls ABS and Heater blower) A/C Compressor, freon recharged Replaced by me: 4 new tires and alignment at 49k Idler Tensioner pulley and Tensioner pulley assembly (This is gonna be replaced Monday) New spark plugs at 57k (Just done today!) I love my Zetec! No major problems whatsoever.
Posts: 1,196 |
98 SE: 2.5 V6 ATX. 33,900 miles. Bought vehicle at appx. 24K miles.
Under warranty: 24K - Mar/Apr '01 - fuel pump and related problems (due to the dealer) 28K (appx) - June '01 - muffler went 33K (out of warranty but "covered" since two days earlier I had tie rods replaced; either dealer's fault or dealer was feeling sorry for me) - Mar '02 - brake rotors
Not covered: 33K - Mar '02 - tie rods - $222
All I can think of for now, there might have been more. Between my dad's Windstar and my Tour we practically drop one off at the dealer every three weeks. Dad's front end fell last weekend so I've got another month till something else goes wrong with my car. (crossing fingers)
Matthew 98.5 Contour SE V6 It has spent 1.5 years under the wrong identity ;-)
Posts: 195 |
My first Contour, '95 GL, 4 cyl.,mtx.... (bought used with 33k on it) 33,500k...speedometer replaced (warranty) 68,000k?...headgasket blew (warranty) 70,000k?...some internal wiring/switch stuck open ($ 226.00) 84,500k?...both front coil springs broke (recall) (everything else was general maintanence stuff) My second Contour, 2000 SE, 4cyl. atx... (bought used 11/8/01 with 25,610k on clock) 27,000k...dash repair (recall) and that is all....woo-hoo...
----------------------- 2000 Ford Contour SE Toreador Red 4cyl. / ATX. (no mods..can't afford to void warranty)
Posts: 277 |
78,500 on the odo right now problems back left rotor replaced twice under warranty other than that not a dang problem (Me knock on wood several times)
Ryan -------------------- '98 T-Red Mystique LS, MTX, SVT Exhaust, KKM -------------------- You and the Captain make it happen (I'm in college what do you expect?)
Posts: 2,587 |
102K THe only problem I ever had was the PS Pump which was replaced under warranty in about as much time as it took me to walk home from the dealership... man that was a great car!
1996 Contour "Mean Green" (99-02) 2002 Malibu Blue Focus ZX5 - something to hold the PB 15...
Posts: 582 |
not counting recalls...
106,000 miles new engine at 74k, probably oil starvation BS new front rotors at 48k. badly warped waterpump at 68k sensors a few times alternator twice intake glogged with gunk two times
Doug former owner of a 95 SE MTX Now driving a Bravada, no more fun in the twisties! DrGonzo767@aol.com
Posts: 515 |
99 SE Sport ATX 33k Miles
Except for dash peeling up (Don't know if I want the dealer messing with it) and melted Fog Lamps (My fault)...No problems (Knock on wood)
"My Name is Richard. I am a Contouraholic." 1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades; Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod; PIAA 9006 Super White Headlamps AIWA CDC-MP3 HU; WeatherTech Mats Viper 600ESP w/Remote entry
Posts: 3 |
98.5 mystique V6 New Dunlaps at @25000 New front brakes and rotors at 40000 (Last Week!) Recalls That's it. Great Car!
98 Mystique LS
Posts: 3,774 |
105,000 miles
unexpected problems: cassette deck not working @ 17,000 miles, warranty rear shocks replaced @ 23,000 miles, warranty clutch replaced @ 23,000 miles, warranty warped rotors @ 23,000 miles, $210 bad battery @ 37,000 miles, $50 front driver's wheel bearing @ 45,000 miles, $400 dash vent broke @ 55,000 miles, not fixed bad battery @ 62,000 miles, $50 water pump bolt broke in engine while at dealer @ 80,000 miles, $400 to extract stud and rethread
problems from my meddling: rusted rear sway bar bracket bolt (broke inside subframe) @ 95,000 miles, $15 for parts rusted front sway bar link (stud broke) @ 104,000 miles, $15 for parts
maintanance issues: timing belt replacement @ 80,000 miles, $200 water pump replacement @ 80,000 miles, $200 rear sway bar bushings @ 95,000 miles, $40
and several recalls performed (or so the dealers say)
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
