Posts: 767 |
"packrat" where did you get your phillips premiums? How much? Can i get them on the internet? Do they burn at the same wattage? Are the the bluish type, or just brighter whiter light? Thanks
1998 E0 Ford Contour SVT Built on 8/19/97 -- #3101/6535 Silver Frost/Midnight Blue * New Cupholders * CEG sticker =) * 9005 Philips BlueVisions * Sound System: Kenwood eXcelon KDC-X617 HU, RFosgate fnq514 components, RFosgate 6x9 3ways, RFosgate 12" sub, MTX 5ch/800w amp, 1 Farad Cap * Removed Ford emblems * Fogs w/parking lights and aimed up * Brushed Aluminum Style Grills all around * 205/55/ZR16 Bridgestone Potenza RE730's * Removed Headliner * Visit MY SVT website (UNDER CONSTRUCTION)*
Posts: 4,983 |
I purchased them at www.autolamps-online.com They are clear bulbs, not blue tinted, but the light is quite white, almost as white as PIAA Superwhites. ------------------ P. Valdez Las Cruces, NM 1999 navy blue SE Zetec ATX PIAA 9006/H3 bulbs Philips Premium 9005 bulbs Hella Optilux 1100 foglamps Sidemarkers DRL Relay Maxxis UA603 205/60HR15 tires KKM on the way!
P. Valdez 1998 VW Jetta TDI 1.9L I4 direct injection turbo diesel 5 speed manual no mods, no money AIM:PackRatTDI My exhaust smells better than yours.
Posts: 767 |
wow, those look like great bulbs for cheap, 18$ for 9006!
Posts: 5,296 |
PackRat, how did you mount those driving lights??? I'm thinking about those style of driving lights at the same position. But I wonder if I could use just screws to hold them there. Thanks! AK Originally posted by PackRat: I purchased them at www.autolamps-online.com
Posts: 4,983 |
I just drilled holes in the black pastic panel thingy behind the bumper. I mounted them as far back as I could drill the holes because the top lip of the bumper just barely covers the top of the beam and I was afraid the intense heat from the projector lenses might melt things. So far no problems. I think they look pretty good there and are well protected. Access doesnt seem to be a problem either.  ------------------ P. Valdez Las Cruces, NM 1999 navy blue SE Zetec ATX PIAA 9006/H3 bulbs Philips Premium 9005 bulbs Hella Optilux 1100 foglamps Sidemarkers DRL Relay Maxxis UA603 205/60HR15 tires KKM on the way!
Posts: 4,983 |
BTW I just used the 4 screws that came with the kit.
Posts: 5,296 |
Are those screws or nuts and bolts? BTW, I think you can use spacers if you want to have more clearance. AK Originally posted by PackRat: I just drilled holes in the black pastic panel thingy behind the bumper. I mounted them as far back as I could drill the holes because the top lip of the bumper just barely covers the top of the beam and I was afraid the intense heat from the projector lenses might melt things. So far no problems. I think they look pretty good there and are well protected. Access doesnt seem to be a problem either.
Posts: 4,983 |
The kit came with both 2 nuts/bolts and 4 screws. I used the screws since I couldnt access the other side. (Maybe I could have tried, but I was too lazy!  ) ------------------ P. Valdez Las Cruces, NM 1999 navy blue SE Zetec ATX PIAA 9006/H3 bulbs Philips Premium 9005 bulbs Hella Optilux 1100 foglamps Sidemarkers DRL Relay Maxxis UA603 205/60HR15 tires KKM on the way!
