Posts: 339 |
Mondeo's with A/C have pnumatic actuators that run off the engine vacuum to control airflow direction. Mondeo's without A/C have wire operated flaps to do the same. If you post up a picture of the back of your heater controls i can tell you what the Contour uses
Mondeo V6 RS
RS Bodykit
RS Lowered
SVT UIM
SVT TB
SVT LIM
Philips 6000K HID ZENON
Twin Stainless Exhaust
Posts: 339 |
Originally posted by ODC: Damn I really want an cc in the SVT now ... an external temp reading would be soo useful ...
Do Contours not have this? Without rubbing it in i now have TWO outside temp readings!! One on the trip computer and one on the new ATC
Mondeo V6 RS
RS Bodykit
RS Lowered
SVT UIM
SVT TB
SVT LIM
Posts: 6,910 |
Originally posted by 98 SE: What does this mean, and what does the Contour have?
YOUR CAR MUST HAVE THE MANUAL A/C already fitted because the kit will interface with the pneumatic line and the solenoid recircle valve that only tha A/C cars have. If you have a mondeo with cable controlled temperature and air distibuition the kit don't fit in your car.
the HVAC is vacumm controlled in our cars
- 95 Mystique LS - Zetec/5spd
Posts: 339 |
Originally posted by brapple: Originally posted by 98 SE: What does this mean, and what does the Contour have?
should be able to use this system then. The only other part of the car it taps into is the A/C compressor control and +12V. Everything else is controlled by the new loom. Do contours have electronic flap control motors too?
Mondeo V6 RS
RS Bodykit
RS Lowered
SVT UIM
SVT TB
SVT LIM
Posts: 1,066 |
Originally posted by Mondeo V6: Do Contours not have this? Without rubbing it in i now have TWO outside temp readings!! One on the trip computer and one on the new ATC
Nope, and the SVT's are the highest models too. There isn't even a trip computer, just a manual odometer.
Ford of America is so, vastly, vastly different from what you're used to in Ford of Europe.
Posts: 3,816 |
Originally posted by ODC: Originally posted by Mondeo V6: Do Contours not have this? Without rubbing it in i now have TWO outside temp readings!! One on the trip computer and one on the new ATC
Well, if I ever go to Germany (which I hope I do sometime...) I will definatly attempt to fit a trip computer and/or auto climate controls in there.
BTW, there's the dash... also note the clock is only in the 1998 and earliar models... the E1 (1998.5) and 99/00 just had a plastic piece that says "Contour" on it. Oh, and the white is not normal, whoever had the car before me did that.
Posts: 5,621 |
Originally posted by ODC: Damn, me wants
Posts: 258 |
I def. want that climate control hvac from the mondeo !
96 Contour
Clarion VRX935VD
My Car
Posts: 339 |
They even dropped the clock???!! Jees,i know we pay more for our cars but to drop a CLOCK?! They couldn't get away with that here!!!
Mondeo V6 RS
RS Bodykit
RS Lowered
SVT UIM
SVT TB
SVT LIM
Posts: 339 |
Mondeo V6 RS
RS Bodykit
RS Lowered
SVT UIM
SVT TB
SVT LIM
