#12451 04/25/02 08:04 PM
SVT10 Offline OP
I took my car back to Galpin (where I bought it) here in SOCal because I keep having this reoccurring problem with the RPM. It keeps Idling high, not dropping during gear changes, and sometimes when I have my clutch down it actually revs up instead of coming down to the normal .6 or so. This is the 4th time its been back there for this problem the past 3 times they were unable to fix the problem. They changed a valve that was leaking but that did not do it. I even faxed them the FAQ info on this problem but that wasn't the problem either. This is becoming really frustrating and was wondering, would my car be considered a lemon because of this? WHAT SHOULD I DO?? I WANT MY CAR BACK!! confused
Oh yeah, one more thing. They told me they called Ford and SVT and they both told them this is completely normal and that nothing is wrong mad
Thanks
Danny
#12452 04/25/02 08:33 PM
Bad IAC valve or throttle position sensor come to mind. I had this same problem for a while and I just simply reset the computer and it fixed it. When my SVT did it it was very intermitent.
Been going for a month w/o any problems. If they havent reset the comp. ask them to. Or just take the neg. battery cable off yourself and let it sit for 15-30 min. Worked for me smile
-neal
99 SVT...modified
96 GL....the beater
"I live my life a quarter mile at a time. For those 14 to 15 seconds, 16 if I get tire spin, or get a bad jump, or possibly if I have a friend in the car, I'm free."
#12453 04/25/02 08:41 PM
It's normal for the revs to hang for 2-3 seconds before coming down. Emissions demands it now-a-days. If it hangs longer than this, it's not normal...
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#12454 04/25/02 09:44 PM
SVT10 Offline OP
Nah, it hangs a lot longer than that, its not normal. The worst thing about it is that sometimes when I put the clutch in it actually revs up instead of going down. I just called then and they said they replace the IAC valve so they will try to reset the cpu. I'll keep you guys updated ...
#12455 04/25/02 10:07 PM
You know, you can reset the computer yourself. Either disconnect the negative terminal on the battery for 15 mins or pull fuse #4 and then put it back in after 15 mins. No reason to take it to the shop smile
#12456 04/25/02 10:23 PM
SVT10 Offline OP
It's already there laugh
