Posts: 2,166 |
I have the catlouge by SPW and it has a couple of HID products. They have some fog lights by Raybrig, looks like it would fit in the SVT front end. They also have HID coversion kits for the 9006 series, those are made by Nokya. Most of this stuff looks like its imported from Japan, I'm thinking of trying a set. There isn't any prices, nor do they have a wabpage. Anyone heared of these brands? ------------------ David Z. Silver E1 #4808 w/stuff http://4.41.5.82 - free for all http://daplace.spedia.net
Posts: 0 |
huhu man... if HID original... thatz gonna cost you about $700 for fogs and another $999 for head lites
Posts: 2,657 |
david z This place has a kit from Bellof for 9006 series. Only problem is the price. They also have driving/fog lights from PIAA. Again, problem is price and the fact that they are square. http://www.sportscar-parts.com/light.html ------------------ Brad W. 1998 Silver Frost SEKKM Induction--Narva Bulbs 1999 SVT Wheels--BFG g-Force KDW's Custom Acoustics ------------------ "Good leaders are scarce, so I'm following myself."
Posts: 2,166 |
Do you guys know what kinda voltage the HID blubs need to operate? ------------------ David Z. Silver E1 #4808 w/stuff http://4.41.5.82 - free for all http://daplace.spedia.net
Posts: 0 |
all i can tell you is... HID has a "transformer" box to generate power to the lights... dunno extactly whats the power but i will check it tomorrow... also the modification adding the box, they add a much thicker harness... i was thinking in goind to a junk yard and see if they had already a lincoln or lexus head lights bulbs and boxes hanging hehe
Posts: 765 |
The December 2000 issue of 'Bimmer' mag has an article about using ~$400 of Mark VIII parts to convert a BMW to HID. It looked like the same thing could probably be done for a Contour. They have a lower current drain than stock headlights, but they are definitely much higher voltage (thus the Xformer).
1999 Contour SE Sport MTX75 T-Red/Grey Audio: Pioneer DEH-7400MP (MP3 CD), Pioneer TS-A6857 front & rear, PPI PCX-250, Infinity Perfect 10.1 Other: cup holders, cargo net, Blizzaks, Potenza RE950s
Posts: 2,166 |
Whats the different between a ballast and a transformer? ------------------ David Z. Silver E1 #4808 w/stuff http://4.41.5.82 - free for all http://daplace.spedia.net [This message has been edited by david z (edited October 27, 2000).]
Posts: 4,983 |
Ballast regulates voltage and a transformer merely increases or decreases voltage. A ballast will send a short high voltage pulse (600-50k volts, depending on application) to strike an arc and regulate the voltage to keep the arc going. (I'm a light freak!  ) ------------------ 1999 navy blue SE Zetec ATX PIAA headlamp/foglamp bulbs Hella Optilux 1100 foglamps Sidemarkers No performance mods, yet.
P. Valdez 1998 VW Jetta TDI 1.9L I4 direct injection turbo diesel 5 speed manual no mods, no money AIM:PackRatTDI My exhaust smells better than yours.
Posts: 4,983 |
BTW Hella is coming out with a projector auxilliary beam HID system (fog lamp or low beam assist, i'm not exactly sure) Check it out at http://www.hella.de You can check out the Raybrig HID products at http://www.hitechimportlighting.com ------------------ 1999 navy blue SE Zetec ATX PIAA headlamp/foglamp bulbs Hella Optilux 1100 foglamps Sidemarkers No performance mods, yet.
