So what you are saying is...
The Ford waste fire ignition system now magically does not reverse fire the opposite bank just because Ford has decided to use a less expensive spark plug. (single vs double)
BTW - on top of that you do realize that technically the fine wire tip will wear quicker then a standard platinum tip will.
Now I do think the fine wire tip's advantages are worth it myself but then again I don't mind if I have to change plugs more often either.
