chavez Offline OP
Can anyone tell me what diameter the hole size is behind the v-6 badge? Also I want to wire them as turn signals only. In the How To section it shows wires going to both the turn signal and the parking light. I assume both those join together and connect to one lead and the other lead which isn't shown in the diagram goes to the gound correct? Now if I want them to only be turn signals all I need to do is connect one side of the bulb to the diode to the turn signal and the other side to ground right? Thanks for the help.
Yeah, just wire one of the bulb terminals to ground and the other to the signal light wire at the headlight assembly. That's how I wired mine.
As for the fender hole size, I didn't measure it, but I'd estimate it as being 1/2 of an inch(maybe larger)in diameter. Anyone take a precise measurement?
Good luck.
Martin
2000 Contour SE
Martin
2000 Contour SE V6 ATX
Med Steel Blue Metallic\Greystone interior
Mods: SVT grill(insert painted aluminum), foglight mod, amber reflectors removed, gas bonnet lifters, 2nd horn installed, 2001 Focus 16" rims, Knauberized, debadgerized, pre-98 sail panels, Bullitt fuel door, A6 sidemarkers, K&N air filter, TH fix, Flowmaster\glasspack exhaust, clock recontent, trunk release bezel recontent, Mystique rear dome light, express-open sunroof, Ford accessory rubber floor mats, Ford accessory door threshold protectors.
