Yeah, just wire one of the bulb terminals to ground and the other to the signal light wire at the headlight assembly. That's how I wired mine.
As for the fender hole size, I didn't measure it, but I'd estimate it as being 1/2 of an inch(maybe larger)in diameter. Anyone take a precise measurement?
Good luck.
------------------ Martin 2000 Contour SE
Martin 2000 Contour SE V6 ATX Med Steel Blue Metallic\Greystone interior Mods: SVT grill(insert painted aluminum), foglight mod, amber reflectors removed, gas bonnet lifters, 2nd horn installed, 2001 Focus 16" rims, Knauberized, debadgerized, pre-98 sail panels, Bullitt fuel door, A6 sidemarkers, K&N air filter, TH fix, Flowmaster\glasspack exhaust, clock recontent, trunk release bezel recontent, Mystique rear dome light, express-open sunroof, Ford accessory rubber floor mats, Ford accessory door threshold protectors.
