Posts: 1,287 |
I installed my train horn today which is 139db....all i have to say is that it scares the hell out of everyone...sound clip soon to come.
Posts: 404 |
i had em on all my previous cars, and they're really loud! the horn on the tour is weak and sounds like a ginea pig when u squeeze it so i understand y u replaced it, but where'd u mount it all up?!
Posts: 715 |
Where did you get it? Easy install?
Brian W. -------------------- Black 1998 SE 5 speed - TOTALLED
Posts: 404 |
Originally posted by BrianW: Where did you get it? Easy install?
they're cheap and u can get em anywhere like meijers or an automotive store. just not sure where he mounted everything, not tons of room under our hoods
Posts: 6,910 |
get two FIAMM free blasters, 132 dB, they are pretty close to sounding like a pre 98s dual horns, put em in a the factory location
- 95 Mystique LS - Zetec/5spd
Posts: 6,700 |
SOUND CLIP!!!!!
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 4,693 |
You may laugh, but let me tell you what I did with my horns.
To me, one of the best sounding car horns is From the Lincoln of the late 60's and early 70,s. They used three horns, two that are essentually the same as most cars, one each high and low note, with an added third horn with a still lower note. I had the three horns on my 72 Ranchero and it sounded very elegant yet didn't seem offensive even though it was louder.
One day I noticed that the horns on my daughter's Tracer sounder better than mine and started to get restless about mine. The factory horns sound OK, but not great.
Even though most horn systems with dual horns use a high and low note, no two seen to use exactly the same two notes, giving each make and model a unique sound, even when the same horn vendor is used.
I started searching in eBay for the Lincoln horns, and just missed one. Still feeling restless, I bought the Freeway Blasters. They are made by the same company as the stock ones, but are a bit louder. I mounted them up with the stock brackets and tried them out. It was better, both in volume and tone, but still not what I had hoped for.
So I grabbed some jumper wires from my tool box and experimented with adding back one of the old horns and then I tried all four. The tone is still a little better and of course, it is much louder.
So call me crazy, but I played with the brackets and made two short wiring harnesses and mounted the old one back in using the new brackets. It took a little imagination but now there are four horns mounted where there was once only two.
I would still like to find a Lincoln third horn though.
Please, no horny car jokes.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 3,037 |
I used to play with horn combos on my first Integra, since it was really easy to get the bumper off and have unrestricted access. I had a combo on there that was almost the same note, but one was off by like 1/3 step. SOOO grating. My parents even came outside to tell me to knock it off.
Posts: 862 |
Hey can I borrow some of your guys free time, sheesh.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Posts: 2,528 |
Hey Chris you never blew the horn for us at the meet!
