Area highlighted in yellow.
Ford - (Ford, Lincoln, Mercury) Always on the drivers door jamb, but often they will have the color code above where it says "Exterior Paint Code". The code shown below Exterior Paint Code is usually not the correct paint code. Look for a two character code. Also, you may see CC Met on the color plate which means Clearcoat Metallic and is not part of the color code. Occasionally they emboss the color code right in the middle of the sticker. The important thing here is to first look at our colors, make an educated guess which color is correct and then locate that code on the color plate.
Midnight Red Metallic Clearcoat EN/M6697
Desert Coral Metallic Clearcoat FD/M6626
Light Prairie Tan Metallic Clearcoat BA/M6818
Pumice Metallic Clearcoat DK/M6612
Dark Toreador Red Pearl Clearcoat JL/M6771
Deep Navy Blue Metallic Clearcoat K4/M6820
Royal Blue Metallic Clearcoat KM/M6479 (Moonlight)
Pacific Green Metallic Clearcoat PS/M6764
Teal Metallic Clearcoat RD/M6630
Willow Frost Pearl Clearcoat SD/M6766
Alpine Green Metallic Clearcoat SR/M6767
Silver Frost Metallic Clearcoat TS/M6720
Black Ebony Clearcoat UA/M6373
Performance White Clearcoat WT/M6640
Portofino Metallic Clearcoat XC/M6623
Cabernet Red Pearl Clearcoat D6/M6871
Toreador Red Pearl Metallic Clearcoat FL/M6758
Spruce Green Metallic Clearcoat FS/M6860
Dark Satin Green Metallic Clearcoat FU/M6862
Light Denim Blue Metallic Clearcoat K1/M6815
Medium Steel Blue Metallic Clearcoat SP/M6966
Amazon Green Metallic Clearcoat SU/M6922
Harvest Gold Metallic Clearcoat B2/M6926
Chestnut Metallic Clearcoat B4/M6938
