I'm thinking about putting the stock box back in.
Maybe a little off idle, but generally no.
9
Do you have a heatshield on there?? If the intake is just sucking in hot air from the engine bay it WILL be slower.
Cold air =
Hot air =
Which is why the stock setup isn't really that bad. Its at least getting cold air... Although if you set up an intake properly, it definitely has potential to be much better than stock.
1999 Mystique LS V6 Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
F
F
just get the gmk cai extension from fastcougar.com pm him and he will make u one. they are awesome. and solve the hot air issue
2000 mercury cougar V6 5spd 3.0L SVT mated to my HMS tranny...... a wolf in sheeps clothing
Here ya go:
http://www.contour.org/ubbthreads/viewmessage.php?Cat=&message=183443&status=&box=received
Click the link in the PM and then the link in the next window!
'00 T-Red TourSE 2.5L ATX Foglight Mod,Optimized Y-Pipe & TB, FSVT F/P,RU-3530 http://www.cardomain.com/memberpage/688552
9
or you can just buy one from custom cougars.com
My car actually stalled once, but only on the hottest day of the year and after running around for a while.
I ran my car with half the stock box on after that happened so that cold air would be directed directly at the conical filter. It's the best thing you can do until you do get a CAI.
You should lose no power at no rpm point what-so-ever.
A more efficient intake is a win/win situation. Less turbulence and straighter airflow is as well.
I could see it if you were added a longer pipe or one with bends (or both) like in a CAI kit. Then your throttle response and tip-in power would suffer.
However not with a short ram pipe and especially not considering you are replacing the POS pleated accordian tube.
on a dyno, would you see gains from a metal intake instead of that accordian tube?
Mark 1998 T-Red SVT -Needs more Go 1999 Light Prairie Tan, Se Zetec www.cardomain.com/id/tour4reak
9
all i have done so far is replace my airbox with an open cone filter, although I still currently have the acordian POS between the MAF and throttle body, i have noticed a slight increase in how fast my RPM's climb now, so i dont believe that you should loose any down low torque more- more air in=more power
1998 mystique 4 banger atx (wrecked) 1998 mystique V6 MTX --magnaflow muffler-no res, open cone intake(Ractive filter)
