Posts: 18 |
so last night i was out laying the smack down on an 04 Jetta GLI with an intake, ecu and fmic in my 98 SE 5speed...his girl friend asked him "is that his engine making that noise?" I pull over, check the dipstick...bone dry...the motor has a little knock at 4500rpm...what should i do about this?...is there anyway i can replace the rod bearings with the motor in the car?...please pm me with some info, i need help bad!!!! thanks, Nate
Nate Srugis
98 SE, V6 5speed
KKM intake, SVT exhaust
15.6@88
Posts: 4,140 |
you = pwn3d by lack of maintenance.
Your best bet is a 3L at this point. Then you can lay the smack down on R32s as well. If you keep oil in the engine.
Posts: 699 |
Post deleted by KyleH
My Cars
1999 Silver Frost SVT - 80,000km #2603/2760 Aug. 10, 1999.
1996 Mercury Mystique LS V6 MTX - retired @ 323,151km.
1995 Ford Contour V6 MTX-sold @ 214,000km
Posts: 18 |
i honestly dont know why thats so hilarious, my project car is a neon and i know you can replace rod bearings by just dropping the oil pan, and i didnt know if thats the case with contours...
Nate Srugis
98 SE, V6 5speed
15.6@88
Posts: 5,143 |
yeah dude... I bet you were burning oil... and never payed attention to it for a while, and it just got to the too low point... ALWAYS pay attention to the oil dipstick.. I check my oil level once a week if not more. 3l time.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 18 |
I dont think a motor swap is possible...i need a car to drive daily to class and work...
Nate Srugis
98 SE, V6 5speed
15.6@88
Posts: 10,015 |
If you've spun the bearings you can't just swap the bearings and think you're good. The rod and/or crank are probably scored and it'll get rod knock instanlty again.
You can only swap bearings if the engine has not sustained any damage.
The only option for you is a engine swap. Time to roll out the POS neon and fix your SVT.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
