Posts: 6,791 |
Once the idle shoot up, i can't get it to go back down. I've tried resetting the computer. I just don't think it's the best idea to be driving around a few day with such a high idle.
The pipe works just fine for a short drive. It's something after that screwing it up.
Posts: 10,015 |
I'm thinking that the IAC is dirty/faulty which is exaserbated by heat. Try cleaning as I said, whil ethe car is runnig so it sucks the stuff through.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 6,791 |
I will try spraying some TB cleaner. I still can't understand why it's doing it with the pipe but not the accordian
Posts: 10,015 |
Hard to guess without seeing the thing with my own eyes.
AUSSIE ENDLINKS $70
Posts: 1,609 |
Just buy a new one dude...its easy to install
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Posts: 9,602 |
By what you have posted it sounds like a leak in the intake pipe or at the end of the IAC tube that connects to it.
Have you tried the starter fluid method for finding leaks?
Also if you want the TH fix to work the restriction has the be at the manifold end. There is too much air in the tube for a restriction at the intake side to work properly.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 6,791 |
Originally posted by DemonSVT: By what you have posted it sounds like a leak in the intake pipe or at the end of the IAC tube that connects to it.
That was my initial thought as well. But wouldn't it have screwed up my idle from the first second i started it up with the new intake?
Originally posted by DemonSVT: Have you tried the starter fluid method for finding leaks?
I have not tried this. What exactly do you do?
Originally posted by DemonSVT: Also if you want the TH fix to work the restriction has the be at the manifold end. There is too much air in the tube for a restriction at the intake side to work properly.
The restriction is at the inlet on the intake pipe. Should i drill it out? Becuase like i said when the idle was high as hell, i parked my car and disconnected the iac tube and it wen't down. Maybe it has something to do with the engine giving off so much heat and too small of a hole to go through? The primary reason i used the copper cap was to get rid of the moose. Now that the weather is better i'm not to concerned about it.
Posts: 2,807 |
Interesting.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 10,015 |
Drill it out a bit so it still stays in, but it's opened up, you know? Try that and see if it helps.
PS when I installed my old one the grommet for the IAT fit fine with some force it'll pop through just fine.
AUSSIE ENDLINKS $70
Posts: 6,791 |
Originally posted by Stazi: Drill it out a bit so it still stays in, but it's opened up, you know? Try that and see if it helps.
I'll slowly start drilling the hole bigger and bigger, until it hopefully fixes the problem.
Originally posted by Stazi: PS when I installed my old one the grommet for the IAT fit fine with some force it'll pop through just fine.
There was no way in hell mine would fit through. Even when i took out the gromet it still didn't fit. Many different people tried with no success. So i ended up sanding down the ridge that goes around the IAT until it could slide in. I used enough high temp RTV silocone to make a nice seal, on the inside and outside of the pipe. Also i applied silicone to the remaining 3 inlets to ensure no leaks. Thanks for all the help, i really hope drilling this bigger does the trick!
