Posts: 238 |
I finally bought a inside trunk release bezel from a '96 Contour from the local salvage yard. I had no idea that both the hole and the bracket the bezel slides upon was already on my '00 SE. All I had to do is trim some of the carpet away and then install the bezel. It looks a lot better that just the release handle sticking up through the carpet. All I've got to say is that Ford really got cheap with later Contours. My factory floor mats are even cut to fit around the bezel. Definitely recommended!!
------------------ Martin 2000 Contour SE
Martin 2000 Contour SE V6 ATX Med Steel Blue Metallic\Greystone interior Mods: SVT grill(insert painted aluminum), foglight mod, amber reflectors removed, gas bonnet lifters, 2nd horn installed, 2001 Focus 16" rims, Knauberized, debadgerized, pre-98 sail panels, Bullitt fuel door, A6 sidemarkers, K&N air filter, TH fix, Flowmaster\glasspack exhaust, clock recontent, trunk release bezel recontent, Mystique rear dome light, express-open sunroof, Ford accessory rubber floor mats, Ford accessory door threshold protectors.
Posts: 3,598 |
Yup, second thing I recontented on my '00 SVT (after the clock)!
------------------ --Steve Bassen Frederick, MD 2000 Black/Blue SVT #871/2150 K&N Drop-in - Bassani Catback (on the way) THF - B&M Edge Shifter - Energy Suspension MM insert Major stereo mods - viper600 alarm - A6 Sidemarkers - ST200 door scuff plates Clock, trunk release cover, Mystique rear trunk panel, front lower bumper supports recontented
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Anonymous
Unregistered
Anonymous
Unregistered
What trunk release bezel,do the 98's have them?
Posts: 3,598 |
Not sure if the 98.0 Contour's have them or not, I don't think so. I just ordered one for a 98.0 Mystique, 'cause that's what my old car was (they were the most contented of all the post 97 redesigned contiques).
Posts: 681 |
my 98.5 has one...i think they were decontented in '99.
------------------ blake 98.5 E1 SVT #4910, silver frost - KKM, SHOshop pulleys, borla exhaust - 35% tint, momo shift knob, A6 sidemarkers, some audio improvements - yakima roof rack
blake 02 acura RSX type S, arctic blue pearl/ebony - OEM fogs, S2k shift knob, 35% formula one tint, injen SRI 62 chevy C10 fleetside pickup, tan - stock I-6, 3-on-the-tree, currently immobile in my garage former owner of: 98.5 E1 SVT #4910, silver frost
Anonymous
Unregistered
Anonymous
Unregistered
Posts: 361 |
SOrry, could someone explain what you mean by the trunk bezel? is that the pull knob for the fold down seats, or is it related to the spare tire setup? or is it something that enables you to release the trunk from inside the trunk??ha? the last one you say??
Anonymous
Unregistered
Anonymous
Unregistered
Originally posted by Kal: SOrry, could someone explain what you mean by the trunk bezel? is that the pull knob for the fold down seats, or is it related to the spare tire setup? or is it something that enables you to release the trunk from inside the trunk??ha? the last one you say?? Its beside your drivers seat on the left on the floor,its the plastic piece that goes around the trunk release lever.
Posts: 3,774 |
Ford decontented that???????? What cheap *******s!!!!! i loose a little more respect for that company every day.
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
Posts: 52 |
I have that in my 98 Mystique, what does it look like after 98?
Is it just the handle sticking out of the carpet?
2002 Subaru Impreza WRX BBS Wheels with ground effects.
