Posts: 21 |
After replacing both LCA's, and installing the focus shift tower, my car makes creaking noises while turning, like something rubbing on something else. Also, the camber is off. I don't know if it's negative or positive, but the tires look like this from the front / \, just not that exaggerated. Is something broken? I have a stock suspension with 150k on the clock. I'm clueless and desperate. PLEASE HELP!!!!
98 CSVT silver frost
mods: 893 fogs, 2 12" free airs, alpine HU
future mods: LED taillights, In door 8's...who knows?
Posts: 4,270 |
have you gotten an allignment?
~Alex
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 21 |
I haven't gotten an alignment yet, but I don't see how they can adjust the camber. It's not like they can shorten the LCA's. ??
Posts: 21,653 |
Originally posted by schnazlnflanger: I haven't gotten an alignment yet, but I don't see how they can adjust the camber. It's not like they can shorten the LCA's. ??
Can't without aftermarket camber plates. I think when they change toe, that can change camber some, but can't change camber alone without the plates.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,867 |
Some negative camber is normal, and at 150k miles, your car may be sitting a bit low, as well, on the stock springs. (They won't lose rate, but they may sag a bit over time.) As the car lowers, negative camber would be more pronounced.
I'm not sure about the creaking. Could be a number of things... Worn struts? Bad strut bearing? CV joints?Somebody else should chime in...
Function before fashion.
'96 Contour SE
Posts: 4,140 |
measure it and get a number. If it's small enough, then you're a-okay. Neg. camber, at least a little, is good for handling in most cases.
