Page 2 of 2 1 2
#1228664 03/29/05 09:22 PM
You could run an SVT or 3L with OBD-I
There is a little more modification work required then a normal swap of each respective type but nothing major.
The biggest fab work I can think of off the top of my head is the fuel rail work to run the new style injectors. You can't "safely" run your stock 17's on an SVT or 3L engine.
This work has been covered many times as folks have switched to the SVT or RLIM before.
#1228665 03/29/05 10:56 PM
would the ECU from the SVT work on my car? or i'll have to get a chip.
the fuel rail wouldn't be a problem. electronics will be if i have to go there.
95 SE MTX DH UIM, 65mm TB, SC CAI, Quaife, Centerforce, Fidanza, UR Pulley, F/R Strut Braces, Cross Drilled Rotors, S.S. Brake Hoses, 18" Enkei RS5, SVT Engine Mounts+Inserts, MSDS & y-pipe, Trubendz resonated exhaust & MagnaFlow cat
#1228666 03/30/05 12:35 AM
9
.???? couldnt he just use the 19lb injectors though??? i have the svt lim and orange top svt injectors in my 96...just had to splice the fuel rail fuel lines to the cars fuel lines....
#1228667 03/30/05 05:41 AM
I don't know. What did I post...
#1228668 03/30/05 05:42 AM
You will have to get a custom tuned chip.
#1228669 03/30/05 02:10 PM
9
......i was reffering more to the part of doing it safely....but either way i'm sure you already answered it and i'm just replying to raise my post count....
#1228670 03/30/05 02:54 PM
Post 98's have PATS. That's the problem with running them in a pre98. Among other things. You'd need the entire harness also.
#1228671 03/31/05 11:27 PM
does SVT and regular duratecs post 97 contours use the same engine harness?
#1228672 04/01/05 02:57 AM
I think PATS is optional on pedestrian contours so u have to be mindful of that. then there is a differemce from 99 to 00 related to the return/less fuel system which was discussed above. other than that I don't expect any difference between SVT and regular MTX harness.
#1228673 04/01/05 04:29 AM
well after all thinking this throughly i decided not to go with this swap. But i'm going to look for a cougar with a blown engine, that will make a nice project...
thanks guys for all the help.
Page 2 of 2 1 2
