#1228628 03/29/05 01:54 AM
Wee I decided to ditch the breather filter on the valve cover and replace it with an air/oil seperator that feeds back into the intake.
This hase been coved on CEG before but I'll do it again.
Supplies (all at Walmart);
One Cambell-Hausfeld general purpose mini filter($11).
Two straight nylon 3/8" hose barb connectors with 1/4" MPT to screw into the filter ($0.75 each).
One 90 degree nylon 3/8" hose barb connectors with 1/4" MPT to screw into the airbox ($0.85).
Two 1.25" wide washers with 1/2" hole ($0.37)
One nut to crew onto 1/4" MPT, I forget the size ($0.63)
Very straight forward install;
1) Remove everything from wrappers
2) Remove airbox
3) Screw the two straight connectors into the mini filter
4) Put one of the washers on the MPT thread side of 90 degree connector
5a) If you still have the original line from the valve cover, remove it now
5b) Put the connector (mpt thread side) through the hole on the airbox where the original line feedback in
6) place the second washer on the inside of the airbox over the mpt thread and screw on the nut
7) Reinstall airbox
8) Find place to install filter
9) Run hose from valve cover to "in" side of filter, then run hose from "out" side of filter to connector on airbox
10) Your Done!
My install is only temporary for now,
I didn't have enough hose to mount the filter where I wanted.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
#1228629 03/29/05 02:25 AM
Where do you plan on mounting it? Think it really will do any good? I might have a friend do it for me (I know, it's easy, I'm lazy) since he did one on his srt4.
#1228630 03/29/05 02:41 AM
On the firewall.
Yes, there is always oil in the air.
And the filter is 5 microns which will catch the larger unburnable particles.
This is good for high mileage engines & really good for boosted engines.
And will be beneficial for when I decide to let the nitrous flow.
It has been thought that its also helpful in performance by acting as a vacuum allowing the cams to spin with a little less air resistence.
Might be good for .01 HP
#1228631 03/29/05 02:42 AM
CEG road warrior
CEG road warrior
Looks like something I need to do.....Sleeper when are you coming to Chicago?
#1228632 03/29/05 02:44 AM
If you can't build & install it I will loose all faith in you modding abilities.
#1228633 03/29/05 02:46 AM
CEG road warrior
CEG road warrior
It's not that I can't do it....I am just lazy....I need to install the Focus SVT fuel pump/new tensioner still. I have a 2.3 pulley sitting here too....but I still need to order the w/i.
#1228634 03/29/05 02:49 AM
Lazy @ss!
Stop munchin on "insert favorite munchie here" and get out there and mod the car!
I can build them for anybody if they want them,
for cost of parts + shipping.
