Page 2 of 2 1 2
#1228378 03/30/05 03:18 PM
Originally posted by BrianW:
What do you do with the cherry picker? Does that hold the engine in place when you drop the subframe? Is there two engine mounts that hold the engine the rest of the car...would that be sufcient to hold it in place?
Trying to figure out if I can do a swap myself. Might pick up an extra trans, build it up(inside and out) and then swap it.
Thanks!
Probably uses it to raise/lower/hold the engine up. You only have the one top passenger side mount connected when all is said and done (you have to remove the driver side as it bolts to the tranny).
I just used a jack and 2x4 under the oil pan to hold mine - the manual recommends "three bar engine support or equivalent" and I guess a cherry picker is equivalent I felt okay with my method as the manual recommends "Place a floor jack and a block of wood under the transaxle and raise the transaxle enough to release the tension on the three bar engine support, or equivalent. " so if that was okay I figured holding up the engine minus transaxle with a 2x4 under the oil pan would be fine.
-EDIT-
"Slowly lower the transaxle until it reaches the limits of the front engine mount movement. "
This sounds straghtforward enough, but when you start lowering the engine with the one mount still connected it's pretty freaky to watch the rubber stretching like it did, but it holds up fine.
97 Contour SE MTX K&N 3530, UR UDP, 19# Injectors, mystery mod, FMS wires, Fordchip.com chip, SVT: TB, Flywheel, clutch, exhaust 04 Grand Caravan SXT
#1228379 03/30/05 09:45 PM
Yeah I dropped all that stuff into my bellhousing for a dramatic effect when stazi opened it up....I swear...
98.5 SVT
#1228380 03/30/05 11:05 PM
ive done it both ways, dropping the tranny and subframe is teh easier method definetaly. i dont have a lift but i got a cherry picker. and as for getting the tranny back onto the engine. put the tranny on my chest, rolled under on a creeper and lifted it into place went in almost instantly
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
#1228381 03/31/05 05:14 AM
The motor mounts are bolted to the engine and the subframe. No subframe, no mounts to hold the engine.
Besides a cherry picker, there are "bridges" that erect above the engine bay to support the engine from above.
#1228382 05/18/06 06:54 AM
bringing this back from the dead, but has anyone actually just lowered the driverside subframe and slide the trans over to reach the clutch? i was just thinking about that since with the saturns you can drop one side of the subframe and pull the trans out very simple.
thought id through it out if no one has done it, because i think i will.
1997 Saturn SL2-project car (salvaged now, current tear down) 1996 Ford Contour-DD, up and running again STC-OH member My SL2 and other cars
#1228383 05/18/06 12:58 PM
What do you think Stazi and I are talking about?
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=tranny&Number=1092176&Forum=tranny&Words=tranny%20removal&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=1092176&Search=true#Post1092176
#1228384 05/18/06 02:33 PM
Yup I just used this method, I think it was the first time I ever said "that was pretty easy" when working on this car. Would have had the trans out in under 4 hours if it wasn't for the shift rod end being seized onto the tranny.
96 Mystique Black On Tan V6 MTX Port Matched 01 3L, 2.5L Cams, 2.5" Exhaust Optimized y-pipe, SVT clutch, Superchips, 3L split port LIM, SVT UIM, Intake, Mustang 65mm TB, MSDS Headers. Eibach Pro Kit, Torsen Diff., Ford Racing 17" Wheels.
#1228385 05/18/06 06:22 PM
ah the search i put in didnt bring that up. but all i wanted to do was lower the driver side and slide the trans over to gain access to the clutch. didnt want to remove it.
Page 2 of 2 1 2
