Page 1 of 4 1 2 3 4
#1225860 03/25/05 07:11 AM
F
F
i got a 1996 ford contour gl. i want to put subs in it. i already put in new speakers and head unit. i was wondering if anyone has done this b/c i dont know if i will need a capacitor or not. some people tell me i will and others say i wont. others tell me to just get a high output alternator. i will only be running 600 watts at most but most likely only 300-400. has anyone done this and if so what have u done. thank you so much for your help!
#1225861 03/25/05 08:05 AM
I don't think anyone has put subs in a Contour before ( ), but for 600 watts you probably wouldn't need one.
#1225862 03/25/05 04:25 PM
Subs in a Contour? I don't know if that's a good idea. Why not just play the factory speakers at real high volume?
....ok seriously though, no problem with 400-500watts in the 'tour
1999 SE White AVH-P6500DVD Infinity Reference 6500CS Pioneer 5x7s Punch 360a2 Punch 500a2 Adire Tempest in a custom sealed 3.4cuft box Modded Xbox Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
#1225863 03/25/05 04:53 PM
I
I
ive actually had dimming lights from about 500 watts, my battery is 12.6v at idle. (95 contour). i think ill get my alt replaced soon
#1225864 03/25/05 05:02 PM
Try upgrading your cables first.
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
#1225865 03/26/05 08:24 PM
I've been thinking of doing this for a long time, but the atl is so hard to get to. Any worhtwhile suggestions on a DIY?
#1225866 03/26/05 08:58 PM
what 500w amplifier are you using?
2000 SVT Black/Tan #1633/2150 (a few mods) Alpine: CDA-9835, MRV-F540, MRD-M550 PG: TANTRUM-X 6.5 COMP all around. Some people wear Superman pajamas. Superman wears Chuck Norris pajamas. CEL currently: Off
#1225867 03/27/05 04:00 AM
ive had a 600 watt amp in a beretta , the alternator was on its way out and teh lights would dimm alot
if ur alternator is new or fairly new u really wont have to worry about it, but i would get a 1 farad cap just to be sure and help prolong teh life of ur alternator
ur lights will dim but only during high volume low bass hits , nothing major but it will still happen
if ur really worried about it and want more power upgrade ur alternator
1997 30th Anniversary SS,Jethotts/ORY/GMMG, 160thermo, ,TB bypass, 1LE intake elbow, BMR STB, 32mmswaybar..21mm rear,BMR LCAs, PR,SFCs,TA,LT4 KM,255lph, shift kit
#1225868 03/29/05 07:21 PM
Hi, not sure if your running 2 amps or not (1 for speakers and 1 for subs) but here is a suggestion. This is based on my system and have no dimming whats so ever with a stock alternator.
I am currently running a RF550x for my front and rear speakers (70 Watts RMS x 4) and a RF350s for the subs bridged (350x1 RMS).
Power from battery (fused) to rear, into a fused distibution block, ( 4 awg input, 8 awg outputs ).
8 awg output to 550x for speakers. 1 ground distibution block - ( 4 awg input, 8 awg outputs ). 4 awg ground from chassis to distibution block. 8 awg groung from block to 550X.
8 awg power and groung from Dis. Block to .50 farad Cap. Then 8 AWG power and ground from Cap to 350S for subs.
Basically the Cap is in between the 2 amps and only hooked up to the Sub amp where you need it most. Works great!
If you want try hooking up your system first as though you might not even need to worry about a Cap or Alt.
99 Contour SE Zetec 2.0 ATX My Ride
#1225869 03/29/05 11:00 PM
Captain Impound Boy
Captain Impound Boy
I would get a Stroker for sure if i had a Contour!
Page 1 of 4 1 2 3 4
Moderated by  dnewma04_dup1
