Page 5 of 5 1 2 3 4 5
Originally posted by Reg E:
One question (though it may have already been answered): Do any of you that have the higher-wattage bulbs installed in the low beam and high beam sockets have a relay added in order to accomodate the higher wattages?
If the answer is "no" or "no additional modifications are necessary," then I may need to look into purchasing these bulbs.
I have the PIAA Super Whites on my SVT now; but if I can get the same (or better) brightness (I really like the white light) at one-third of the price just by replacing the PIAAs with these bulbs, then I may be selling my PIAAs too!
[This message has been edited by Reg E (edited September 11, 2000).]
That is another reason I didn't put in the high beams. If you do the calculation W/V=A you'll find that the standard fuse will not cover the bulb. If you increase the fuse size will you burn up your wiring harness? Anyone have anything to add?
Martin
Martin
99 Silver Frost SVT
#1060 of 2760
New 2000 engine at 25K thanks to Ford
18x7.5 Alba Blaze rims
225/35x18 Bridgestone Potenza S-03 Pole Position tires
EBC Sports brake rotors in front
EBC GreenStuff at all 4 corners
Pioneer DEH-P3000 AM/FM/CD
Pioneer TS-A6813 all around
JC Whitney Diamond Blue 65W low-beams
Sylvania 885 50W fogs
DRLs
Anonymous
Unregistered
Anonymous
Unregistered
Martin
Ive got the high beams in,and use them alot,no problems,no blown fuses.I even started my car and turned on the high beams for about 45 mins,to see if the lamp housing or wires were going to get hot,they did not.
So no problem.
I've had the JC Whitney low beams for about 8 months now and they do look great. And I've had no problems with the higher wattages burning my lenses. I only replaced the low beams because the stock lows were seriously weak. The stock highs seem fine but I may replace them, just for looks.
Martin
Mhconley
Any problems with the 80wt bulbs to date? Do you run your fogs with these bulbs also? Any problems?
1998 SVT Contour
Silver/Midnight BLue
1673 of 65355
00' SVT Rims
KKM Pedal Covers
KKM Sill Protectors
Mobil 1 5w30
K&N Air Filter
1998 SVT Contour
Silver/Midnight Blue
1673 of 6535
00' SVT Rims
KKM Sill Protectors
Mobil 1 5w30
K&N Air Filter
Mobil 1 badge(from the cobra R)
50% tint
~100,000 miles
