Posts: 1,224 |
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 8,143 |
don't the mufflers hang down in the back? I see its not quite like an SVT exhaust. Damn look at that flex pipe  Its tiny, that needs replacing now!
Posts: 5,143 |
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 4,155 |
I bet it sounds pretty deep for a 4 cyl engine!!  And your flex pipe happens to be in great condition..unlike mine
Posts: 1,238 |
Wow talk about losing torque....wait its a Zetec.  j/k  Looks good but there better be a turbo or something going on there for a 3" exhaust. -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 21,197 |
Originally posted by ButtonPuncher: I want to be able to give Hector a run for his money.
BP
Sell it and get a manual. You won't even have to modify it.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 2,211 |
Wow, just seeing that Brullen system brings back some memories of that Group Buy I did......
It must have been at least 2 years ago when I did that, why so long to put it on????
Posts: 3,709 |
Originally posted by SVTCuervo: Wow, just seeing that Brullen system brings back some memories of that Group Buy I did......
Good point! I was going to ask where he bought it from! My brullen is still going strong! Wish I would have gotten the Ypipe aswell.
btw, is it me or does the muffler set back a lot further than the passenger side?
Originally posted by Chickens: Religion can't do much for ashholes (unless you are an alterboy)
98.5 Se w/SVT mods
98 E0 SVT~ sold
Posts: 9,065 |
Originally posted by trasmusse04: Originally posted by ButtonPuncher: I want to be able to give Hector a run for his money.
BP
Eesh.
but tru...
Posts: 4,155 |
You'll find that mine does the same thing, slightly less
I think it's because the two (frame and exhaust) are not welded together and hung by rubber for removability; in which, the rubber hanger gives slightly to the amount of force the already tight fitting exhaust system is applying to it.
It's not as bad as having it stick out AND sit lower. That's what happens if you do not get a passenger hanger welded to your car.
