Posts: 2,007 |
Am I fugging invisible?
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 6,910 |
Originally posted by Y2KMondeoSVT: Originally posted by brapple:
... from my experience with the install the how to is adding a ground to make the led work ...
I added nothing , along with many others that did this mod in the past . Maybe Ford recently changed the switch ?
you have to add a wire to the switch, it isn't there to begin with, at least in my car ...
Originally posted by amarv12: Am I fugging invisible?
I was backing up what you said
- 95 Mystique LS - Zetec/5spd
Posts: 6,910 |
the how to says you add a wire to pin #4 pre 98 window switch sunroof switch as you can see pins 4 and 5 are used for the for powering the light, pin 4 is the ground and pin 5 is the power. you can use the power wire in the harness for power and I connected the ground like it said in teh how to
Posts: 2,838 |
No no no ... what I meant by "I added nothing" was "I added nothing more than what the How-To called for" . I added the D79 connector to "pin 4" , connected to the black wire in the overhead light (just like in the How-To) . Do the "new" lighted moonroof switches have 7 pins ?? Mine only had the 6 , like in the How-To (part #F8RZ-14529-AA) .
Sorry for the confusion on my part .
~~~~~~~ Phil
Black & Tan 2000 SVT Contour #2137 of 2150
35,000 miles & counting !
Posts: 6,910 |
Originally posted by Y2KMondeoSVT: Sorry for the confusion on my part .
don't worry about it, partly my mistake also
don't forget the images I posted are for the pre 98
post 98 switches should have 6 pins, it seems the light gets its power internally from the switch and not the outside like the pre 98, but I bet that has something to do with the lights being an option in the light package on pre 98s
Posts: 317 |
What would be the part number for the post 98 switch? I got mine to work, but I must be using the wrong wire for power because the switch stays lit whether the ignition is on or not.
Originally posted by LUCA: Yep.
You can be Phil too if you'd like.
Posts: 317 |
Dumb question, I just saw the answer. The pre 98 switch (the one I have is F5RZ-14529-A). The one I should get is F8RZ-14529-A (post 98).
Posts: 317 |
I just re-wired the connections as per the wiring diagram and everything works fine. Thanks guys for all your help.
