Posts: 52 |
Okay I have to think alot, but not as much as the worst person here. I've had the following done: 1. Wheel bearing (drivers side) 2. Rotors(this is bad, check your hand brake) this will bite you in the ass for rotors, especially back ones. 3. Recalls all except the front spring ones. Getting the wiring harness done hopefully this week. This is a beater from now on. 161000 km. 4. Basic maintainance. Fixed the clock light easily. 5. Water pump hasn't been destroyed yet, in my life with this car. Had it from 49000 km to 161000 km. Thank god. 60 km per day. bought in 99 to present april 19/02.
All in all good power until I get home the car is dead. Not sure if it is the cat or cats that are heated so much to reduce power, maybe a cluck thing. 97 contour v6 LX - wouldn't buy another, but its hard to find the price that this was for the power.
Please reply if lack of power after 30 km, highway for 15 and stop and go for the rest. Later Fred
1997 Contour LX V-6 Tan
Freddy3675@yahoo.com
Posts: 308 |
71,xxx and only a battery and window regulator (still need to find one)
Posts: 1,053 |
just under 50k
Changed rear end links to quell banging/knocking at ~43k
Water pump (precautionary) at 45k
Plugs at ~30k to fix small hesitation/stutter I was feeling. Seemed to fix it.
Regular oil changes, anywhere between 3.5k - 6k
I still need to fix a leaky trunk, sticking handbrake and notchy shifting. I have parts/fixes/ideas for fixes for all 3. Time & motivation are on back order.
Regards...
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course." #9 - Hitting .400 for ever "Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez "The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
Posts: 486 |
20,000 new fuel pump and new front rotors (back is drum)
35,000 new dash new front rotors (had to fight for it this time)
Black '99 Mystique LS Duratec ATX
Posts: 97 |
98 E0 with 93K. Replaced first cat @ 77K under warranty. Other than that, nothing, other than oil changes filters, belts, etc...the stock clutch hasnt even given out yet...go figure, one of the best cars I've owned.
98 E0 SVT Frost Silver No mods...yet.
Posts: 1,444 |
33k...
I replaced the driver side seat. It rocked and made to much noise. That's it as for normal problems
Everything else I ***** about on this board were caused by me moding my car...wheels, exhaust, intake..not fitting right. You get the idead
Posts: 52 |
I wonder what day the car was finished(friday, wed., Monday). My car is OK so far. I expect more problems though. This car is problematic. I wanted to get ride of it, but the loss was to high. The market know about our vehicles, and its best to get the value of the parts on this vehicle. I mean it stupid to sell this vehicle, 2000 canadian loss automatically. Anyway keep the research going, because this site is the best. I know exactly what is going to go wrong next. If I win the lotto I will place a huge amount here. The waterpump is scaring me. I had it from 49000 km to 161000 km , and it was alot of traveling between Ottawa, and Montreal. I have slacked off since the girlfriend is now living with me. Please give me advice about changing this soon, or symptoms of what to look at. I inspect this pully every night, I wish but I do it every month. And I watch the oil temp. Thanks Fred
Posts: 1,445 |
just short of 91k miles purchased april 01 with 70256 miles....
replaced waterpump themostat transmission and trans mount plus one motor mount at 89k miles in feb 02
new serp belt at 90k...need new alternator soon...but thats it and most of the work has been covered under used car warranty
my tour's been driven only ~2000 miles since work done but i put 19k miles on it in 8 months...great miles all around
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 401 |
Spooky post! I just bought my tour at 43k 2 months ago, just hit 50k- thought it would be better than the Focus I was offered at the dealership. So far no problems- Dash was replaced before I got the car- showed up on the Oasis. Haven't found any recalls that I need to check into- anyone know anything I don't. Plan on doing some preventive stuff like water pump, motor mounts, etc.
99 SE Sport 2.5 Duratec Spruce Green Metallic.. Aesthetic Only.... For Now
...the closest I will ever get to having a Turbo will be the Gillete Mach 3 variety!!!
Posts: 249 |
Owned a 97 GL Duratec - bought at 80 miles.
Front seat cushion replaced under warranty. Four wheel alingment done at around 13,000 miles. Battery replaced at around 62,000 miles.
The rest was all basic maintenance.
