Page 3 of 5 1 2 3 4 5
10-15% of sh~t is still sh~t...
What the point?
Oh yeah there is none.
Get an Torsen or Quaife LSD. Period.
9
Just curious cus I have a 95-97 tranny in mine.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Originally posted by Stazi:
Face it. The MTX-75 diff is a piece of sh!t, even if Il Papo blessed it himself.
but I give his diff my blessing.
so now it's a blessed piece of sh!t.
87 Mustang GT 5.0L TURBO
Aman, hestika sta yelia vre! Oraia!
Then eniai pou then ehoune lefta - then ehoune mialo, mono skata me rigani!
The mou les, thas pas stin eklisia etho stin Livonia yia paska? To xeris...stin Konstantino kai Eleni?
va sou po alithia, vomiso tha pamai. Eiki eivai tnv ekleisia mou. Pas katholou ekei? den exo pie, apo ta xristougavia.
Exies pai sai eliviki xopos katholou etho? Ei felei mou pava katha dio evthomathes. On thelies va arthies!! Va sou po, olli philie mou eivai ellivies. Liges fores sexanouma americanous. Eivai malakes.
Tha pao proti fora yiati molis irtha etho stin Livonia. Prepi narthis sto spiti mou cami fora, Endaxi?
Ok, enough Greek for now.
Demon's right, and basically was reinstating my post. All the stock diffs are weak... Are the pre 98's better; possibly. It's is better to apoint where it's worth persuing - NOT AT ALL!
The pre-98 diff gears are Powder Metal formed gears (like a cookie essentially, and cookies aren't very strong are they?). Post 98 diff gears are billet cut gears (like a wood carving). What happens when you hit a wood carving? It breaks along the grain right - Yep, essentially the same thing that happens to billet gears, the teeth shear off.
My bad it's the other way around Post 98 is PM, and pre 98 is billet cut. Either way; same [censored] different bucket.
9
If I ever have to pull the tranny again, assuming its not from the diff, I am gonna put a tortion in. So how could they have made the gears so that they would last?
Not sure exactly what you're asking, but the Torsen is a TOTALLY different diff design to the stock open design. That alone is an improvements aside from the materials and heat treatments used in the Quaife and Torsen.
The Quaife and Torsen are Helical Differentials
Originally posted by warmonger:
IIRC the only difference on the roush tranny's is the zetec final drive.
Same diff, all other gears the same.
You will still need to perform all the same improvements to this transmission that you would any other pre-2000 tranny.
The torsen or quaife will fit fine.
Exactly - the Roush aka Bob Bondurant tranny has one difference ONLY the zetec final drive.
The diff is the same piece of glass as in every other MTX-75.
Gewt a Quaife or Torsen in that before you use it. Period.
They claimed there was more done to them than just the FD. Perhaps it was the harder POS open diff?? I purchased 5 of them, but can't remember
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
W
W
Got any more?
No, the last 3 sold almost 2 years ago. They were the very last I could find..... wish there were more
