Page 2 of 8 1 2 3 4 5 6 7 8
#1222603 03/24/05 02:39 PM
Hmm. sounds like your chip never actually was working if it's the same with it on there on not.
Did you even clean off the silicon over the J-port connector contacts?
#1222604 03/24/05 03:38 PM
O
O
i just put my ADC chip on yesterday...the biggest pain was gettin the power steering reservoir off. First under the dash on the passenger side, undo the 10mm bolt holding the clear plastic clip onto the computer. Second go into your engine bay on the passenger side and if you are looking at the power steering reservoir there are two clips that hold onto the shock tower but there is a little clip in the middle that holds it in place. First you need to get a screw driver or something so you could pry the reservoir off, *Note* it will slide strait up, then there is a 10mm bolt right behind it holding the wiring harness, just unscrew the bold all the way and remove the harness. The computer should be real easy to remove now. After the computer is out get a 7/32 socket and remove the 6 bolts holding the computer together. You will see a port with a coating over it, thats where the chip is going to plug in. Before you plug the chip in you need to get fine sandpaper and lightly sand off the silicone so the chip and the port make a strong connection. *Note* there is a black plug in the computer that you will need to remove so the chip will fit, just use packaging tape over the hole where the chip is so stuff doesnt get in there. After the chip is in, re-install your computer in reverse order and everything should work.
#1222605 03/24/05 05:53 PM
dude trust me the chip was working and working awsome,,,rev limiter from like what is stock 5k now its at 7,600 the gas mileage, air fuel, touque, everything it made a huge differance from stock and the chip is out and the result from the chip is still there.....my mechanic/sct authorized dealer dosent know how its happening....maybe the pcm learned it and saved it or something. i dunno but its still screamin like the chip is in there
#1222606 03/24/05 06:06 PM
Cameron 98 Black CSVT #2958
#1222607 03/24/05 06:15 PM
Y
Y
HAHAHAAAA!!!
Step into car, look at tachometer, see where stock redline is, come back and post when you have a clue!!
Mark
#1222608 03/24/05 06:17 PM
HA HA HA yeah we can all live without a smart mouth,hahaha just kidding i am one too...no i am at my desk at work yelling at people all day so i cannot remember for the life of me what it is...but its at 7,600 now,,,i dont always shift there unless i am on a track or something like that,hehe
#1222609 03/24/05 06:40 PM
For the record your ECU will NOT learn what's on the chip. The chip when installed overides the base program, when you remove it it reverts back to stock end of story. If you think otherwise, you're sadly mistaken. It simply is not PHYSICALLY possible for it to do that. The only way you can change the base setting for good is with a reflash. And I've seen only one dude do that. He's an ex-Ford programmer and has the "box" that allows him to access and rewrite the settings.
#1222610 03/24/05 06:57 PM
ok dude whatever, you can think that if ya want but i know what my car is doing, i pulled the chip last thursday night before i took it to carmax and on the way there everything was still the same ,even my mechanic drove it and said wtf...looked for the chip and it wasnt there and said i dont know how that is happening.....if you dont belive me cool i dont care......
#1222611 03/24/05 07:03 PM
Stock SVT rev limit is ~6750 at least the one that makes it fall on its face when you hit it is IIRC...not 5000. Here's a thought...what RPM does your car idle at ? If it's up around 1200...check you tach and I would guess somebody has been messing with the gauge needles...perhaps a indiglo gauge install? If you don't know what you are doing with these the speedo & tach can be way off when installed and will require recalibrating.
Scott 2000 Contour SVT #1464 Mustang Dyno: 171.6hp/145.3lb Dynojet Dyno: 171.1hp/148.9lb 1989 20th Anniversary Turbo T/A "Indy 500 Pace Car" #1376 of 1550 All Original, 46k with a few mods 2002 F150 SuperCrew
#1222612 03/24/05 07:10 PM
Sorry I didn't realise you have the limited edition MAGIC SVT that defies the laws of physics and hence electronics. My bad.
