Page 2 of 2 1 2
Anonymous
Unregistered
Anonymous
Unregistered
NO NO NO NO,DONT PRY IT!!! I made the same mistake!You will scratch it all up!
Here is how to do it.
Where the read out is(12:00p)there are two small holes,youll have to look under the frame of the glass of the clock,stick a small pick or precision screwdriver in one of those holes and pull straight out. [img]http://albums.photopoint.com/j/View?u=221252&a=1637915&p=24767366&Sequence=0[/img]
[This message has been edited by HWCM (edited July 21, 2000).]
I recontented the clock in my 2000 SE today, and noticed something that may be important.
According to the instructions posted under the how-to section concerning clock recontenting, the blue-black wire on the radio harness is for 12V accessory and the white-green wire is for illumination. On my car, the blue-black wire is for illumination and a yellow-green wire is for 12V accessory(I don't have a white-green wire). Like the instructions say, just be sure to double check wires with a voltmeter or test light! Maybe 2000s are wired different or Mexican-made Contours(like mine) have an alternate wiring harness. Anyway, the clock looks a lot better than the "Contour" nameplate! Now I have no excuse for not knowing what time it is, I have two clocks(dash and radio)!!
Martin
2000 SE V6 ATX Med. Steel Blue
A6 Markers
Knauberized
Mondeo badges(nameplate and V6 emblem)
SVT Grille
Glasspack/Flowmaster exhaust
Clock recontent
Fogs on w/parks
Pre '98 sail panels
Actual French license plate on front(gives neat "Euro" look)
Martin
2000 Contour SE V6 ATX
Med Steel Blue Metallic\Greystone interior
Mods: SVT grill(insert painted aluminum), foglight mod, amber reflectors removed, gas bonnet lifters, 2nd horn installed, 2001 Focus 16" rims, Knauberized, debadgerized, pre-98 sail panels, Bullitt fuel door, A6 sidemarkers, K&N air filter, TH fix, Flowmaster\glasspack exhaust, clock recontent, trunk release bezel recontent, Mystique rear dome light, express-open sunroof, Ford accessory rubber floor mats, Ford accessory door threshold protectors.
Page 2 of 2 1 2
