#1221157 03/20/05 09:27 PM
Does anyone have some experience with decals and rear window wipers?
My wife has a 2000 Windstar and we are going to get decals put on three windows of the van to advertise our DayHome. The questions are,
1. Will the rear wiper screw up the decal?
2. Is there a fuse that will dissable just the rear wiper alone if the decal will get messed up.
If not I guess I could just remove the arm all together.
Thanks for your help,
Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning* 2000 Windstar SEL K&N Air filter
#1221158 03/20/05 09:54 PM
I
I
You're going to rice out your minivan? Good luck.
#1221159 03/20/05 09:57 PM
N
N
I can see over time it wearing off. But if you clean the area before applying the sticker, and make sure you stick it on good, I wouldn't see a problem with it. Also after you wash the area, and apply the stick... take a hairdryer to it. Makes it get rid of the moisture on the inside.
Good Luck!
Steve
Steven. L. Benthal Jr. 98 Mystique: Meshed Grille & Pioneer Sound System
#1221160 03/20/05 10:55 PM
Just don't use the rear wiper.
#1221161 03/21/05 01:01 AM
the rear wiper will start to make the edges/corners come off. either dont use it or disconnect it.
ive done the vinyl thing quite a few times in my day, with truck clubs and people ive known who've owned vinyl shops.
here's a little advice to make it go on nice, easy and straight!
1. first clean the window with windex or whatever.
2. get a spray bottle and fill it with water and add a little dish soap to it.
3. spray the area where the sticker will go liberally.
4. apply the sticker
5. use a credit card to push out any air bubbles and excess water.
6. allow to dry over night. do NOT drive the car, they may fly off or move.
*it should dry perfectly with no air bubbles. if there are any the next day, slightly cut them with a razor.
the reason for the soapy water is that it allows you to slide the sticker around until you get it riiiight where you want it. it will have ZERO effect on it permanently.
nothin like trying to place a big vinyl sticker just right and accidently putting it on crooked then trying to peel it off so you can try it again.
#1221162 03/21/05 04:13 AM
Online Content
Impossible in a Windstar. Our old '98 had a rear wiper that would activate if the front wipers were on and you put the car in reverse.
#1221163 03/21/05 04:14 AM
ever hear of wire cutters?
~Andrew
2001 VW Jetta Wolfsburg Edition 20 valves of fury
#1221164 03/21/05 04:16 AM
a Windstar.
herein lies the problem. i know a few people who've owned these and EVERY single one of them was owned by them. get rid of it before it's too late.
#1221165 03/21/05 04:18 AM
Online Content
a Windstar.
Ours went to 120k fine ... only real problem was the (recalled) front springs kept breaking, but that's probably because my dad loaded that thing past its payload with plywood, shingles, and other construction materials every few months ...
#1221166 03/21/05 04:23 AM
What idiot designed that...oh wait, it's a FORD.
