Originally posted by JonsZX2SR:
Also, if you go with a true dual system a crossover pipe or 'X' pipe located at approximately the same distance as the 'Y' pipe will promote even better flow than separate dual exhaust pipes.
As long as you retain the 180 degree bend and not use straight downpipes! (ala SHOShop/BAT)
Otherwise a misplaced X or H pipe will degrade performance.
