Posts: 44 |
i want to run a small vent or scoop over the left side of my hood. Does any one make misc vents or scoop? thanks
1996 Contour LX ATX V6 Ford 9mm blue wires--Bosch platnum +2 plugs-kkm intake--SVT throttle body--Superchip(on the way)--20% tint--side markerlights--Badgeless
Kenwood Cd Deck--MTX mono amp--MTX 15" Thunder 8000(soon)
Posts: 3,066 |
 How's this? :p Stazi, and Rye Lou have put scoops on their hoods. I don't know where pictures are. I think SVT Kris did too...
STD's are like Pokemon... Gotta catch em' all!
Posts: 3,066 |
Posts: 151 |
Subframe Connectors, H&R's, Koni's, Rage 5.0 17's, Pole Position Tires Removed Resonator,KKM Intake,ShoShop Y-Pipe 3 liter to be built by Terry Haines or BNoon one of these days...
Posts: 44 |
i need something functional for cold air to reach my filter
Posts: 972 |
mine were hacked though, probably would have looked decent had they been fiberglassed on and painted body color, it was, however, functional
95 SE Champagne Mettalic True Dual exhaust with X pipe and Redline mufflers KKM Tru Rev intake H&R Springs/KYB struts Apex-i S-AFC 65mm Throttle Body 17" Ace Spades 4 Pt Racing Harness Window Tint all around New Engine @ 117k kilometers G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass" quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
Posts: 3,237 |
Originally posted by cougarboy1989: i need something functional for cold air to reach my filter The scoop shoots air right onto my filter and the vents evacuate heat from under the hood. Everything you see is functional. plance1 - bite me! :rolleyes:
Posts: 249 |
Stazi, do you have any problems with water entering the intake when it rains hard?
~~~~~~Mike~~~~~~ Silver 2000 Contour SVT # 1200 of 2150
Posts: 2,481 |
Originally posted by SVTMike: Stazi, do you have any problems with water entering the intake when it rains hard? That shouldn't make a difference, nor it shouldn't deter you from getting the vents. Dont listen to these morons that tell you not to get the vents. Base your decision on if you like the looks and if you want better heat extraction.
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 2,481 |
Here is a pic of my old SVT with hood vents.
