Removing the plugs and wires isn't too bad. I've done it quite a bit the past couple weeks, trying to track down a problem. Oh, and did I mention I have a front strut brace that sits right on top of the rear bank?
Really though, it's not too hard. Remove the front cover. Use the same sized socket to remove the coil pack. Pull the wires out, plugs out, and then reinstall everything. Just remember to connect the ground wires onto the coil pack. Oh, and don't recommend doing it when the engine is hot. For one you can burn your (my) fingers and second you should never remove a hot spark plug, could mess with the threads.
Tim
'00 SVT
