Where is the neutral safety switch located on an automatic V6?
1996 Contour LX----Fully Loaded Sony Xplod 650X 52Wx4 HU
Pioneer TS-A6865 in doors
Goodyear Eagle HP Tires All Around
Hanging Black Dice
Bocsh+2 DoublePlatnium Spark Plugs Red Spark Plug Wires
EBC Greenstuff Brakes
EBC Sport Groved Rotors
It's part of the MLPS (manual lever position sensor). It is on the trans where the shift cable attaches. Top side of trans under air intake tube.
Jim Johnson
98 SVT
is it hard to replace
Hanging Black Dice
Lee Offline
If your talking about the solinoid switch that keeps the car from shifting into gear without the brake depressed, then it's on the shifter mechanism under the consol. You have to remove the consol to replace it. The consol is four screws in the front, and two in the base of the arm rest. It takes about 30 minutes to get it out if you've doen it before abotu an hour if you haven't.
Lee Cox
In life begins responsability...
Project Car
9
9
The neutral safety switch is the device that keeps you from starting the engine when the transmission's in gear and is part of the MLPS as Big Jim stated.
Karl
*** It's all about consistency! ***
98 SVT Contour
86 Ranger GT
69 Fiat 850 Sport Spider
67 Formula-S Barracuda
my reverce lights don't work and i think that is the culprit
Hanging Black Dice
9
9
Quote from horseydug from similar post last year:
For the atx the back-ups are controlled via the TR (transmission range) sensor which is located in the engine compartment. This device also controls the starter interlock.
Karl
98 SVT Contour
86 Ranger GT
The transmission range sensor and the manual lever position switch are two names for the same thing.
Jim Johnson
98 SVT
