Posts: 1,145 |
the torx size is either a t-10 or a t-15, cant remember which one for sure. and no a phillips head will not work, you will just end up either striping the screw or throwing the screw driver at someone.
98.5 Black SE ATX
Posts: 925 |
we call them pollen filters
Posts: 1,593 |
Originally posted by gearhead98: the torx size is either a t-10 or a t-15, cant remember which one for sure. and no a phillips head will not work, you will just end up either striping the screw or throwing the screw driver at someone.
Thanks. On my car, it was actually a T30 Torx screw. It made the change in about 20 minutes, following the instructions from the Mods section. It was DEFINITELY time, as the filter was really dirty !
Thanks for everyone's help.
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
Posts: 610 |
bosch is the cheap ones that are made of the same stuff as cheap air filters, now the ones that are like 40 bucks from valvoline or 300 from the dealer, are the stock HEPA cabin air filters recommended by ford.
2002 Cougar
2.5 duratec/ mtx-75
85,0000
Mondeo ST-200 wheels/BFG KDW NT
black/black
Spec Stage 1
Torsen T-2
Trubendz 2.5 flowmaster dual exaust
apexi s-afc II
K&N FIPK
Posts: 685 |
i gota puralator at Advance for $16....fits perfect
Justin
98.5 CSVT # 4887 of 6535 (born 2/28/98)
Posts: 3,709 |
Originally posted by ContourGuy9817: bosch is the cheap ones that are made of the same stuff as cheap air filters, now the ones that are like 40 bucks from valvoline or 300 from the dealer, are the stock HEPA cabin air filters recommended by ford.
I wonder if K&N makes one? That otta be good for a +10 increase of interior ventilation horsepower!
Originally posted by Chickens: Religion can't do much for ashholes (unless you are an alterboy)
98.5 Se w/SVT mods
98 E0 SVT~ sold
Posts: 1,593 |
Originally posted by XKontour98: Originally posted by ContourGuy9817: bosch is the cheap ones that are made of the same stuff as cheap air filters, now the ones that are like 40 bucks from valvoline or 300 from the dealer, are the stock HEPA cabin air filters recommended by ford.
Posts: 4,140 |
Originally posted by meancontour: Originally posted by XKontour98: Originally posted by ContourGuy9817: bosch is the cheap ones that are made of the same stuff as cheap air filters, now the ones that are like 40 bucks from valvoline or 300 from the dealer, are the stock HEPA cabin air filters recommended by ford.
Not if you don't put the K&N sticker on your window!
Posts: 3,709 |
Originally posted by 95Sleeper: Not if you don't put the K&N sticker on your window!
Doh- details details.
I hear the sticker is where the real Hp is held.
98.5 Se w/SVT mods
98 E0 SVT~ sold
Posts: 1,593 |
Originally posted by XKontour98: Originally posted by 95Sleeper: Not if you don't put the K&N sticker on your window!
I have heard the same thing. It is similar to the extra hp gained by all the Ricers for putting an "R" or "Type R" on their cars somewhere. My favorite are the Toyota Type R's.
Check this out: anti-rice.com for some good laughs. And examples of things to watch out for.
