#121625 07/24/02 09:51 PM
To install 3L valves in a 2.5, what is involved..than pulling engine? Is it a difficult job once heads are off? Are upgraded springs/retainers needed or available. Would love a price "estimate" to both do just the valve install (if heads were shipped) and to remove /replace heads (basically do the job in your shop) from Terry or Brad (on or off forum).
Do you think this is a good next step after getting LIM & UIM all port matched out to 35mm or so, big t.body/MAF meter, headers & exhaust, with A/F tuning last? Yeah, this was my thought to do last as a surprise mod for you all, but now the impending CEG collapse has accelerated my question....Thanks
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
#121626 07/25/02 02:42 AM
H
H
I am thinking the same thing regarding 3L valves.
LIM & UIM port matching pricing too.
I think we can get 250 FWP out the engine. Scotty, give it all she's got!
Even those butterflies are in danger.
98 T-Red Contour LX V6 Mtx 106k miles
9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
#121627 07/26/02 01:01 PM
Heads need to be m/c and larger inserts fitted...
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#121628 07/26/02 01:10 PM
Dan what do you mean by the Impending CEG Collapse!!! Since I haven't been coming on the boards lately much often, I'm not up to par with alot of things...Thanks wink
Performance Xpress Racing
Silverbulitt@msn.com
Our websit www.PXRacing.com is coming soon!!
We carry Contour/Cougar parts for the 2.5 Duratech and 2.0 Zetec
#121629 07/26/02 01:58 PM
Originally posted by Silva Bulitt:
Dan what do you mean by the [b]Impending CEG Collapse!!! Since I haven't been coming on the boards lately much often, I'm not up to par with alot of things...Thanks wink [/b]
OH Well never mind, I found out the scoops and I've already sent money, Thanks wink
#121630 07/26/02 02:37 PM
i think dom on fordcontour.org did the 3.0L valves on his 3.0L short block.
Jim Hahn
1996 T-Red Contour SE
2002 Black Mazda MP5
Latest mods: sho shop off road y-pipe
#121631 07/26/02 02:46 PM
Nope, not that I know of. The only two 3 liters with the 2.5 heads and 3 liter valves are jjennings (David Z's old engine) and Warmonger. IIRC, Tom said his cost under $500 to get done at a local shop. I've got the same quote from a local place here too.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#121632 07/28/02 10:51 PM
3
3
The 3.0L valves will fit the 2.5L heads with out any problems. The overall length and the stem diameters are the same between the valves. I think all you need to do is bore out where the valve seats sit, and then open up the ports in the head to match. Everything else should be the same as a regular valve job. I bet you would use the same valve seats that the Taurus uses to. That would make the seats easy to find for the machine shop that is going to do the valve job. You basically need to have the ports opened up to do this. Why not go all out? Have the heads ported all the way. As soon as I get my hands on a good set of heads that is what I am going to do to. I have the bigger lower intake already. I'm just going to have the guy I use for port work open the intake and exhaust ports up to the edge of the gaskets. Then I'll have him port match everything else. I may even have him match the horrible stock exhaust manifolds to the heads if I don't have the money for headers in time. I think 250@ the wheels is possible with a 3.0L. It's my eventual goal. I would like to see it with stock cams. My car with a 3.0L, the big lower intake, an open intake and a SHO Shop Y-pipe made 215 @ the wheels through the STOCK exhaust!! I had a set of U/D pulleys to. There has to be 35hp in there.
Roger
98 SVT E0, Black
Blown motor, help on the way......
97 GTI VR6, Green
#121633 07/31/02 11:43 PM
well my thought is that at least on later SVTs (I understand port size increased in 98 or so?) the intake ports are already 34mm, which is the size of the 3L valve seat opening. So asside from opening up the port around the valve seat where it tapers down to 31-32mm, I can't see a reason to open ports up to BIGGER than the valves. Exhaust side may be another story..not sure of ports sizes.
Experts feel free to correct my errors..
#121634 08/01/02 02:31 PM
Often ports neck down right before the valve to increase gas velocity just before going into the chamber. This also keeps fuel from puddling on the back side of the intake valve. wink
Brad Noon
'99 SE MTX
